2010 engine vibration
Discussion in 'Gen 3 Prius Main Forum' started by sl2w0, Apr 19, 2019.
  1. sl2w0
    sl2w0 Junior Member
    Eastern Shore, MD
    I’m new to the forum and now realize these issues are fairly common. My 2010 with 232,000 just started to get the engine vibration when accelerating and is burning oil. I’m not sure if it’s worth getting fixed or if I should sell it. I’m not comfortable doing the work myself.
  2. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    It sounds like the EGR System needs to be cleaned. At 232K, it's probably clogged. If you can DIY, clean it, there are many videos on this topic. See @NutzAboutBolts videos in the maintenance section. If this work is not performed soon, the head gasket will probably fail soon due to excessive engine heat.
    If DIY is not your thing, then your best bet is to move on, replace the car soon.
  3. padroo
    padroo Senior Member
    2,763
    2,253
    How much oil are you burning?
  4. sl2w0
    sl2w0 Junior Member
    Eastern Shore, MD
    1.5 quarts since last oil change, 6,000 miles ago
  5. bisco
    52,742
    sell
    Raytheeagle likes this.
  6. JC91006
    16,928
    8,637
    Can't DIY, sell
    mjoo and Raytheeagle like this.
  7. sl2w0
    sl2w0 Junior Member
    Eastern Shore, MD
    Any ideas what the value would be in this condition?
  8. orenji
    orenji Senior Member
    5,887
    3,488
    1.5 quarts in 6,000 miles is not bad for an engine with so many miles. You should be changing the oil at 5K miles. So this really is not bad.
    padroo and Bay Stater like this.
  9. padroo
    2,763
    2,253
    Have it checked out it might be something simple before you just give up on it.
  10. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Where are you located?
  11. sl2w0
    sl2w0 Junior Member
    Eastern Shore, MD
    Eastern Shore Maryland
  12. bisco
    52,742
    you can check the value on kbb.com
  13. Mendel Leisk
    42,223
    Do you have AutoTrader in the States? Try Googling:
    AutoTrader 2010 Prius
  14. padroo
    2,763
    2,253
    The oil consumption isn't that bad for a car with that mileage, I would at least have someone see what the problem is. It is the cheapest option, don't throw the baby out with the bath water.:)
    sl2w0, Bay Stater and Raytheeagle like this.
  15. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    +1;).
    If we only could be given a clue as to where the OP is:whistle:.
    padroo likes this.
  16. sl2w0
    sl2w0 Junior Member
    Eastern Shore, MD
    Not sure what you mean, I did say where I’m located.
  17. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    When you have under 5 posts, they do not show up automatically ;).
    Having a location listed on your profile can help get local support when required.
    Have you tried any local shops or know any mechanics in the area? I’m not sure what mechanics there are around, but @danlatu and @wjtracy arent too far away and might have more to offer(y).
  18. sl2w0
    sl2w0 Junior Member
    Eastern Shore, MD
    Ok thanks
  19. danlatu
    danlatu Senior Member
    533
    1,367
    maryland
    Burning engine oil tends to fowl spark plugs. Incomplete combustion will cause engine vibrations and may not throw a code. Did you install new plugs @200k. Is you egr cooler, pipes, egr clean and the ports that go through the intake plenum? A compression test would also show an imbalance of combustion on all cylinders. If your compression is low on one cylinder because a valve does not fully seat will cause crazy vibrations. I would start with a full cleaning first.
    Bay Stater, sl2w0 and Raytheeagle like this.
  20. sl2w0
    sl2w0 Junior Member
    Eastern Shore, MD
    Plugs were done at 200,000. EGR cleaning has not been done. I have experienced a cold startup engine shaking in the past, no codes right now. What it is doing now is different, more of a rattling/knocking during acceleration. I’m just trying to decide if its worth putting money in to and see what other people have done when they get this many miles.
