2010 - Front Wheel Bearing Replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by eseerc, Sep 20, 2019.
  1. eseerc
    eseerc Junior Member
    53
    Central PA
    Hi everyone,
    I have a 2010 with 195k miles on it. For about 10 days, I have noticed a loud "humming" noise from what I thought was my left front tire when traveling at high speeds (70+ MPH). My dealership checked it out tonight and determined my driver's side front wheel bearing is the cause of the noise and needs replaced. I was quoted a little over $600 total for the repair ($380 parts, $220 labor).
    1. Is this something I should have repaired ASAP? I am unsure if the vehicle is unsafe to drive for myself, let alone with my children in it.
    2. I do plan on having the bearing replaced, but the quote seems pretty high to me. My dealership has always treated me good and am ok with paying a little extra for their service. However this seems to be quite a bit high. Does anyone have input on what would be considered a reasonable expense for this repair?
    Thank you in advance!
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Pay half that at an independent shop
    52,789
    you can drive it for awhile, but i would get another quote, make a decision and get it done at your earliest convenience
  4. spiralhelix
    spiralhelix Active Member
    255
    220
    Illinois
    i bought my wheel hub from 1aauto.com for around $100 for the pair. I installed it myself, but there are a couple challenges. If you aren't prepared to do the job yourself, then you might save a little on parts at an independent shop, and maybe a little on labor. I don't know what the tech manual says for a repair time...but honestly I'd guess probably close to 2 hours of labor. The hub will more than likely need to get pressed out which adds to the time (especially if you do it yourself, my shop charged me $35 to press it out). Then keep in mind, it will need a wheel alignment afterward since the tie-rod has to come off.
    I drove for quite a while before tackling the job simply because the noise wasn't changing or getting worse with time and I didn't have a great place to work on the car at the time, but in the end my noise was just a worn tire (i know, should have just changed that first, but it didn't change with a tire rotation. Just turned out all the tires were worn, ha! The hub was definitely cheaper than all 4 tires. Also, I only installed one side, so I still have a good hub ready to get installed in the event that i need it.
