2010 Fuses keep Blowing
Discussion in 'Gen 3 Prius Technical Discussion' started by Novavill, May 28, 2020.
  1. Novavill
    Novavill New Member
    I've replaced all the fuses plus the one on the battery and the 125 amp fuse in the middle of the fuse box. I also went ahead and replaced the inverter/ converter. The main abs no 1 and the ecu - b2 fuse keeps blowing . I accidentally reversed polarised the battery/don't ask smh. So have no dash lights and power button doesn't work, But the lights on the inside comes on and the emergency lights work. What is everybody's thoughts and what could the cause of my problem be? Thanks in advance.
    52,891
    i think you are going to have read the trouble codes. make sure you use tech stream
  3. RRxing
    RRxing Senior Member
    2,564
    1,842
    NEPA
    Did you reverse polarity before or after replacing the inverter?
  4. Novavill
    Novavill New Member
    I have tech stream but I didn't think it would be able to pick up anything if I can't get the car into start mode?
    Before replacing the inverter.
    #4 Novavill, May 29, 2020
  5. bisco
    52,891
    if it won't perhaps the service manual has suggestions
  6. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    o_O
  7. Novavill
    Novavill New Member
    Yea I'm stumped, nothing on the dash comes on and the only two fuses that keeps blowing is the main abs no 1 and the ecu - b2 fuse. (n)
  8. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    I meant start mode doesn't exist.
  9. Novavill
    Novavill New Member
    No the power button isn't working or lighting up. The dash doesn't come on at all.
  10. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    Since you say your reversed the polarity of the battery, which I can't understand how that happened,
    I would suggest it's a good bet that your probably fried the main abs no 1 and the ecu .
    Or perhaps the wiring for them.
