2010 Gen 3 Prius and 12V Battery Question
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by viprius, Nov 30, 2016.
  1. MeGuinness
    MeGuinness Member
    217
    78
    UK
    Would A not so good 12v battery give any performance problems to the car even if it manages to start it ok ?
  2. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    It may result in lower than normal mpg numbers.
  3. MeGuinness
    MeGuinness Member
    217
    78
    UK
    Well lately I'm down to 45mpg from the usual 56mpg ..... unless the 5w30 oil change is the problem?
  4. Mendel Leisk
    42,369
    First time using the heavier oil?
    Could be onset of winter too.
  5. MeGuinness
    MeGuinness Member
    217
    78
    UK
  6. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Any reason for the heavier oil, like reducing oil consumption?
    I have used 5w-30 for over 25 k miles for oil consumption reduction. Have not noticed that significant of mpg reduction by switching, maybe 1-2 mpg but I would say negligible. But oil consumption has gone down :).
  7. MeGuinness
    MeGuinness Member
    217
    78
    UK
    Yes I wanted to see if would consume less oil as it drinks 5litres in about 8k
  8. Mendel Leisk
    42,369
    8k miles I assume? Looked up GB units a bit.
    That's getting to be a thirsty car. How many miles on the odometer?
    Raytheeagle likes this.
  9. MeGuinness
    MeGuinness Member
    217
    78
    UK
    Raytheeagle and Mendel Leisk like this.
  10. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Try anything else to help slow the oil consumption?
    I was at a quart every 4,500 miles before doing the following:
    1. Intake manifold cleaning
    2. Pcv valve changeout
    3. Egr cooler and egr valve changeout
    4. Switched to 5W-30 synthetic oil
    5. Fuel injector treatments with BG Products 44K (twice)
    6. Engine Treatment with BG Products EPR (PN 109) before the 140 k mile oil change
    7. Added BG Products MOA to this oil change
    Began to notice the oil consumption around 120 k miles and still experimenting ;). At 145 k miles now.
    I look forward to your update(y).
  11. MeGuinness
    MeGuinness Member
    217
    78
    UK
    What I have done
    1 intake manifold cleaning
    2 egr pipe cleaning
    3 fuel injection treatment
    4 switched to 5w30 oil
    I have to try to take out completely the egr valve to clean it.
    What is your n.7?
  12. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Here are some pics of the products I have used to answer your question on what #7 was:
    EPR (used this to remove carbon deposits):
    MOA (used to reduce friction and should help swell the soft materials to reduce oil consumption):
    One school of thought with the MOA is that the additives in it keep the oil basic longer. This should help the softer materials avoid acidic attack from the combustion process, hopefully reducing the blow by and oil consumption. It also is a great lubricant which should help avoid frictional wear in the engine.
    The other school of thought is that it is "snake oil" and does nothing. I figured for $14 it was worth a shot. I was going to switch the oil to high mileage anyway,so I had nothing to lose:).
    Google it and you will see some interesting videos about what it does and you can decide for yourself. I personally like the video with the chevy 350 running for 12 minutes with the oil pan dropped off the engine and the temperature of the engine stays under 100 F.
    They also make an extended life MOA that I will try in the next change and compare the differences between it and the standard MOA. That is supposed to last for a 10-15k oil change interval:
    Hope this helped and answered your question. Keep us posted on your situation (y).
  13. Mendel Leisk
    42,369
    @MeGuinness Your oil consumption is a revelation. I mean: what the hell?! What does Toyo say is "acceptable", a quart every 600 miles? Sorta sums up their attitude. :confused:
  14. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    And their only response is to do a consumption test. It is left up to the owner to carry the mail and check the dipstick frequently. If not caught early before the dash light illuminates, we know the result :(.
  15. MeGuinness
    MeGuinness Member
    217
    78
    UK
    This thread is diverting big time ...but I removed the egr pipe ... again... doing this once a month nearly.... it seem stuck again....torch light test .. before and after the cleaning
  16. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Wow that's pretty severe:(.
    What type of gas do you buy? Is there any high detergent gas available?
    What does the egr valve itself look like and is it functioning? And what about the intake manifold? Did each of them have as significant of buildup?
  17. Mendel Leisk
    42,369
    When the object is to solve a problem, it's best to just go where it goes. No big deal.
    So that's the "missing" oil that's blocking the pipe I guess. The upstream EGR cooler is likely totaled??
    If you dive in, I would follow Ray's approach with the cooler, and maybe the EGR valve proper as well: have replacement on hand. Then you can clean the old cooler at your leisure, be ready if-and-when there's a next time.
    #37 Mendel Leisk, Dec 4, 2016
  18. MeGuinness
    MeGuinness Member
    217
    78
    UK
    Cleaned as much as I could the valve access ....gosh it looks a pain to reach the left nut
  19. Mendel Leisk
    42,369
    Have you removed the wipers/motors/windshield cowl? For the EGR cooler (if and when you tackle it), I strongly suspect that'll help. (See @NutzAboutBolts spark plug change video in maintenance section). That and pull of the engine underpanel with the car raised.
    Ray keeps mentioning he trimmed something before re-install: he's the EGR pioneer.
    (I've actually come across instruction in the Repair manual, about cowl removal, but the video is just as good if not better, since it's hands-on. There's no critical torque values I think, just common sense.)
  20. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Access is difficult, but you'll find a way;).
    Looks like you also took the screws off of the egr head. If you can't get the nut off of the back of the left side, you can at least actuate the plunger on the egr and see if it is stuck.If it was, at least you freed it up:).
    At some point I would pull the cooler and egr valve and inspect. With the amount of deposits in the egr pipe, Imagine what might be in the cooler.
    See if you can get a spare cooler and valve from a salvage yard. This way they'll be clean and shorten the replacement process some.
    Good luck(y)
