2010 Gen 3 Prius Fuel Pressure
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ReadyToRoll, Apr 18, 2022.
  1. ReadyToRoll
    ReadyToRoll Junior Member
    34
    South Carolina
    What is the least expensive way to read fuel pressure? Most mechanics and dealers are at $125+
    I have a wifi OBDII device and some app on my phone but do not think it gave this info. Purchase was just for 1 year anyway and has expired. A local mechanic I know hooked up to his device for multiple vehicles and the fuel pressure info was blank. He did input vehicle data, ect. but still no pressure info.
    At 205k and still only 45mpg after doing all mentioned EGR, plugs, intake cleaning and fuel treatments I wonder if fuel pressure is holding me below 50mpg?? Only other maint I am thinking is cleaning the CAT if I read a good way to do that.
    Thanks for any help!
  2. JC91006
    16,936
    8,647
    If it makes you feel any better, I get about 42mpg on my 2010 in Southern California since day 1
    Montgomery and ReadyToRoll like this.
  3. likearaptor
    likearaptor Junior Member
    38
    Idaho
    In the winter here I get low 40s and in the summer maybe around 45. Depends on how you drive. When I go 85 I only get 39 mpg bit then again any other car wouldn't be getting in the 30s at that speed normally, so I'm happy with it. I think anywhere in the 40s is good. If it was always in the 30s I'd do some checking
    SM-G991U ?
  4. Mendel Leisk
    42,347
    Our 2010 (Canadian) Touring has the 17" rims, like your V, which impose a mpg penalty.
    My current lifetime average is 47 mpg (5.0 liters/100 km). Latest tank is showing 46 mpg (5.1 liters/100 km). Calculated is more'n likely around 43~44. Time of year, trip length, terrain, everything makes a difference.
    Screen grab from Fuelly.com, and this is mostly levels with 15" (easier rolling) wheels:
    Attached will hopefully help with your fuel pressure check, but yeah, not sure it's worth pursuing:
  5. mr_guy_mann
    mr_guy_mann Senior Member
    4,118
    2,014
    NJ-USA
    This car doesn't have a sensor to read fuel pressure. Any OBD2 adapter, app, or scantool can only report data sent over the network from a ecu. No fuel pressure sensor, no fuel pressure data.
    Besides, if someone who understands how engine controls work could look at fuel trims then they could determine if fuel pressure was causing any problem. I might expect to see fuel trim codes or driveability problems before it affected MPG.
    Things that reduce MPG: driving habits, tire choice and inflation, suspension condition and alignment, ICE condition (intake or exhaust restrictions, compression, valve or ignition timing, injector faults) , powertrain function (trans- hybrid drive), body aero , etc.
  6. ChapmanF
    19,025
    As mr_guy_mann said, there isn't a built-in fuel pressure sensor, so there's no chance of just asking the car about the pressure. The car can be asked about other things that may suggest whether mixture is or isn't a problem.
    If it becomes a matter of reading the fuel pressure, that has to be done by plumbing a pressure gauge into the system. Even at a dealership they'll just unhook the hose at the firewall and MacGyver something up with a tee and fittings. They have part numbers if you want to do the same 'official' MacGyverage that they would.
  7. ReadyToRoll
    34
    South Carolina
    Thanks for all the replies, I will quit thinking about fuel pressure then. I agree, not worth the effort.
    Sounds like I should be happy with 45 from other posts, I will try and not pay attention to the 50+ posts!
    Montgomery and Mendel Leisk like this.
  8. Mendel Leisk
    42,347
    Yeah those 17" porkers take a toll. :unsure:
  9. PriusCamper
    PriusCamper Senior Member
    13,465
    5,431
    Pacific Northwest, USA
    It's a Prius V... That's slightly better than normal MPG for that car. There's nothing wrong with your fuel pressure, they're rarely a problem in modern cars. If you want to boost MPG further gradually boost your tire pressure up into 40's until you notice slightly less traction on roads you drive most often and then back it off a couple PSI for safety's sake.
  10. Tombukt2
    Tombukt2 Senior Member
    13,861
    2,519
    Durham NC
    47 on our Persona w 17 50 series . Pretty much all time wife driving . So stepping on it leaving lights
  11. Mendel Leisk
    42,347
    Maybe we better clarify. In 2010 the Prius levels were I through V (Roman numerals), in the States. OP’s avatar says 2010 model year too.
  12. PriusCamper
    13,465
    5,431
    Good point... Was going to fast when I made that conclusion.
  13. Montgomery
    Montgomery Senior Member
    2,254
    2,243
    Orange County, CA
    Low to mid 40's is the norm for higher mileage Gen II's. And as already noted, a lot of it depends on the time of year, grade of gasoline, long distance driving versus short and rim size. The Gen 4's really took a leap in mpg.
