2010 Gen III Prius Rear Wheel Hub Assembly Replacement Issues
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by rpjarader, Mar 15, 2017.
  1. rpjarader
    rpjarader New Member
    Marblehead
    Good Afternoon, My husband replaced the rear wheel hub assembly on our Prius now the check engine light, abs, break light, and traction control light is on and the ABS system is not working but car drives fine down the road. What could he have done wrong?
  2. Mendel Leisk
    42,343
    Couple of things I can think of:
    1. Rear speed sensor wire is disconnected to the new bearing.
    2. 12 volt battery negative cable was not disconnected at the outset of the swap, and the car is detecting some anomaly. Whenever the caliper is pulled off, and then reinstalled, it's good to tromp the brake pedal multiple times, get everything "seated", before reconnecting 12 volt neg. cable.
    Also, it'd be good to check the caliper piston is oriented correctly, locked on the inner brake pad's pin on backing plate. See the brake pdf (attached) for more info on alignment. A simple way to check now for drag: raise the rear of car, and try spinning both rear wheels. If there's heavy drag, it's lkely misaligned. Slight drag is normal. Or simpler: after a drive, feel rear wheels. If there's excessive drag they'll be hot.
    jcjkbjr, Prius_Angie and Raytheeagle like this.
  3. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Just drive a few blocks and light will clear
  4. Mendel Leisk
    42,343
    The sensor wire might also be connected, but damaged. There's been at least two reports here of the wire being damaged by not being disconnected prior to hub removal. It's maybe hard to get at the connector while the hub's still on? At any rate, when the hub comes free, it can be with some force, stress/break the wire and/or connector.
    So even if everything still looks ok, there might be damage in the connector or the wire.
    #4 Mendel Leisk, Mar 15, 2017
  5. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    The plastic Casing around the sensor is a bit fiddly and opens like a clam shell. Not intuitive when looking at it. But when you have it apart, you can see what is going on. That could be a potential failure point, this leading to issues.
    It could also be that the brake pads and Caliper were taken off and the piston was too tight to allow rotor to be placed back on with the pads. If you move the Caliper piston to open it, then do not pump the brakes prior to reconnecting the 12 volt negative, it might trip the ABS and other systems.
  6. Mendel Leisk
    42,343
    Weird, I do the opposite. When I've had the caliper off the rotor, rotated the piston and reassembled everything, I'll purposely pump the brake pedal, make sure everthing's seated, prior to reconnecting the 12 volt. My logic being to avoid the car's systems detecting excess brake pedal travel, throwing codes. So far it's worked, having had it open twice now.
  7. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Read the last paragraph of my post and we are saying the same thing;).
  8. ChapmanF
    19,017
    I thought you were saying "do not pump the brakes prior to reconnecting the 12 volt negative" and Mendel was saying to do exactly that ... ?
    -Chap
  9. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    I tried to outline the most likely scenario I think happened in "If, Then, Consequence" layout. Sorry if I did not state it clearly.
    I have done a rear hub assembly on a 2010 Prius once and the piston was hanging up on the pads and would not allow the rotor back in. Had to get "the dice" tool out to push the piston in far enough to allow everything to fit back together. Once assembled and wheel on, pumped the brakes, then put the negative on the 12 v battery.
    No codes and a quieter ride;).
    Hope that helps(y).
    tankyuong likes this.
  10. Mendel Leisk
    42,343
    @Raytheeagle I looked again at what I quoted from you (my post #6), and it finally clicked: I'm misreading "then do not pump the brakes". It should be read as "If you then do not pump the brakes, you could subsequently trip the...". Understand now. (y)
    Raytheeagle likes this.
  11. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Thanks for the suggestion. As an engineer, my communications skills can occasionally leave something to be desired:oops:.
  12. rpjarader
    Marblehead
    Well any other suggestions? Could just replacing one wheel bearing cause the issue?
  13. Mendel Leisk
    42,343
    Get the codes read?
  14. rpjarader
    Marblehead
    C0210
  15. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    That's for the right rear speed sensor. Worth looking at the wiring and connection again. Did he disconnect the speed sensor prior to removal of the old hub assembly?
  16. Prius_Angie
    Prius_Angie Active Member
    245
    229
    Saint Louis
    #16 Prius_Angie, Mar 20, 2017
    Raytheeagle and Mendel Leisk like this.
  17. rpjarader
    Marblehead
    Yes, he is pulling the tire back off tonight and we are going to check over the wires again and make sure the connection is okay. We will disconnect the battery neg. first.. I'll let you know what he finds.
  18. rpjarader
    Marblehead
    Well looked over everything again and it all appears okay. Going to have a third party look over the car. Thanks for trying to help
  19. imran Arshad
    imran Arshad Junior Member
    New york
    Hi
    Did you find the solution for c0210 code?
    I have same problem and I have change the wiring and wheel hub but code is still there?
