2010 Gen3 Prius Steering Wheel Climate Button Problem
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Canard, Nov 11, 2024.
  1. Canard
    Canard Member
    223
    Ontario, Canada
    This is a 2010 Gen3 Toyota Prius. The steering wheel mounted climate controls (temperature up, down, and recirculating) have stopped functioning. They still illuminate the “phantom” display on the dash, but do not modify the climate settings themselves. This leads me to believe it is some kind of fault not at the steering wheel itself. What could it be?
    (before you say "clockspring", please note that the phantom display still works up on the dash, which means a signal is getting from the button on the steering wheel, to the car itself.)
    #1 Canard, Nov 11, 2024
  2. ChapmanF
    19,033
    The signals that light the Touch Tracer display (when you lightly press the buttons) and the signals that work the controls (when you fully press the buttons) are carried through the "clock spring" on different wires. (The exception being TRIP and DISP, as those two wires are the ones that get repurposed in the Touch Tracer models to carry the touch info.) See this post.
    Canard likes this.
  3. Canard
    Canard Member
    223
    Ontario, Canada
    Thanks - I was forgetting that the "button press" and "lightly touching a button" are two completely different functions.
    I guess I am lucky that it is a redundant signal (I can still modify the climate controls obviously on the console), and not something like the TRIP or DISP functions, where there is no secondary button...
    #3 Canard, Nov 13, 2024
