2010 Gen3 won't start or go into ready mode.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jnls, Aug 26, 2018.
  1. jnls
    jnls New Member
    albuquerque
    2010 prius wont start. Everything is been replace new, even 201V battery pack, engine&transmission fluid replaced new, brake also new. Only radio is disconnected. Try to start, push button show amber light, it doesn't start the hybrid battery, it put into park, cant shift into neutral. all Lights are working. OBDII is not working, can't read the code, is has power voltage to the wire, but it didn't read any code.
    Any ideas, please help.
    thanks
    JNLS
    #1 jnls, Aug 26, 2018
    52,819
    you'll have to take it to a dealer, a shop with tech stream, or your own copy and a compatible laptop.
    Raytheeagle and ITBland like this.
  3. JC91006
    16,936
    8,647
    Did you replace the HV battery yourself? If you did, did you lock the orange interlock switch on the battery?
    You have to lock it into place or your car won't start
  4. Al Bundy
    Al Bundy Member
    140
    69
    florida
    is the radio part of the security system? if its disconnected or missing the car might not start, have you tried to press lock then unlock on the fob with the doors closed to reset the security system?
  5. ASRDogman
    ASRDogman Senior Member
    8,055
    4,083
    The main question everyone seems to ask is how is the 12V battery?
    If it's low, the car won't start. If it sat for a while it could be low, since you said you couldn't read the codes,
    even though the lights light.
    Have you tried charging it?
  6. jnls
    jnls New Member
    albuquerque
    none of these comment is help, it not about the battery. They all BRAND NEW. even back up charged from AC house hold. Nothing to do with the radio, the key work fine, I already tow it out to the Toyota dealership for more investigation. Thank for all comments.
  7. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    OBD not working, there you go. Vehicle computer need to be diagnosed.
  8. JC91006
    16,936
    8,647
    did you read post #3?
    Raytheeagle likes this.
  9. ASRDogman
    8,055
    4,083
    Wow, you come here for help, then get pissed when people help....
    Raytheeagle and Grit like this.
  10. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    He tried PM’s too with a similar tone:(.
  11. Al Bundy
    Al Bundy Member
    140
    69
    florida
    aww well, on to the next person.. some people appreciate it some dont..
    :cautious:
  12. Mendel Leisk
    42,322
    Have you checked the switch on the brake? For the engine to start you have to depress the brake while pushing start button. And for the car to detect you've pushed the brake that switch has to be working properly. They can get out of adjustment I believe?
