2010 - Help! Disabling Reverse Beep
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by sherryp, May 30, 2009.
  1. sherryp
    sherryp New Member
    Santa Cruz
    Steps from previous posts worked with my 2004 Prius - but didn't work with the 2010...just purchased yesterday and would REALLY love to disable the backup beep - any suggestions from technical guys?
  2. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Page 584 of the owners manual says it can be changed from beeps repeatedly to beeps once--needs to be done by dealer, unless somebody here has figured out a DIY.
  3. table9
    table9 New Member
    ca
    I agree the beep is annoying as hell. Least it could do is beep outside so others are warned when my wife drives it.:eek:
    Jeremy Henry likes this.
  4. NoMoShocks
    NoMoShocks Electrical Engineer
    1,292
    82
    Camas, WA
    Manual says the dealer does it with "special equipment". I cant help but wonder if the special equipment is just the service manual that tells you the code such as reset odometer, turn on ignition twice, stand on your head and bark thee times, then open the lower gove box and hold it open for five seconds while opening and closing the uper glove box twice. Shift to B while reciting the Pledge of Alegence, then let all the air out of the front right tire for 10 minutes while singing Joy to the World by Three Dog Night.
    Wouldn't it be crazy if I have unknowingly revealed the actual procedure?
  5. Vincent
    Vincent Don't Wait Until Tomorrow
    641
    31
    South Florida
    Agree about the crazyness of "special equipment".
    Someone must have a guide to adjusting the Custom Features.
  6. PriusCrazy
    PriusCrazy Blizzard Pearl for Me
    213
    28
    Triad, NC
    If this is the procedure I'm going to let the dealer do it! :shocked:
  7. AirKuhl
    AirKuhl New Member
    63
    Santa Cruz, CA
    I just got back from having the dealer do it for me (free). Blessed, blessed reverse silence. :)
  8. sluday
    sluday New Member
    251
    16
    Jersey Shore
    What is the point of the interior beeping ? Is it so a driver does not forget he is in reverse when trying to pull forward ?
  9. sherryp
    sherryp New Member
    Santa Cruz
    HA! That is exactly what the first procedures were like! I'll drop by the dealer tomorrow - pretty good chance the mechanics won't know how to do it either...Thank you!
  10. Tideland Prius
    16,206
    Actually, yes. In a normal car with a shifter position indicator, when R is engaged, it's an orange square over the "R" position on the dashboard. With the Prius, the square is the same white colour and it blinks so it's not as obvious.
  11. sluday
    sluday New Member
    251
    16
    Jersey Shore
    So then it is a good safety feature. Is it that annoying to have it disabled? I mean it only beeps for a few seconds when you back up so I would leave function on. I guess I would have to hear it to make that decision.
  12. NoMoShocks
    1,292
    82
    Camas, WA
    You can get an orange square to flash around the "R" on the Prius too. Use the same procedure, but instead of letting the air out of the right fronot tire, you let the air out of the left front tire. It is for people who pull over the limit line at a stop light, then back up to let a pedestrian cross and leave the car in "R" by mistake so that when the light changes and they do their jack rabit start, they zoom (Hmmm in Pirus case) into to car behind them.
  13. Tideland Prius
    16,206
    do not know but I have mine off :).
    Don't forget to sneeze 3 times and the twirl exactly 2 seconds after the last sneeze.
  14. AussieOwner
    AussieOwner Active Member
    1,091
    67
    Sydney, Australia
    My 2007 Australian version does not allow you to disable the beep, and in two years of driving, having the beep has not really bothered me. But then again, it only beeps when I back out of the garage, or into a parking spot - so it only sounds for a short time. :)
    However, I do agree that it would be better if it was on the outside so that others would also hear it and be aware of the reversing car.
  15. sluday
    sluday New Member
    251
    16
    Jersey Shore
    I think prius owners would be laughed at if the beeping were outside the car on such a small vehicle. To me when I here beeping outside I figure it is a big truck or van. A beeping hybrid would be funny. :D
  16. Mike Dimmick
    Mike Dimmick Active Member
    963
    247
    Reading, UK
    Ironically the reversing beep did not help me remember it was in reverse in the first month or so of owning the car! Had a few near-misses. I think it's that everything else is so automatic, you forget that it doesn't 'know' you now want to pull forward, and change for you!
    Now the beeper is just irritating, and there's no documented procedure I'm aware of to turn it off on a European car.
  17. Richard P
    Richard P New Member
    Trois-Rivières (Qc)
    I think that this feature, along with the LKA and the Intelligent Cruise Control are the first steps to allow blind people to drive !
  18. XMAN LIVE
    XMAN LIVE "Just have Fun!"
    271
    23
    49
    Cypress TX
    too funnny! LOL:rofl:
  19. Blind Guy
    Blind Guy New Member
    352
    194
    Springfield Missouri
    Sounds GOOD to me! But don't tell my wife, she'll want me to do lots of errands for her...and I'd rather play!
    David (aka Blind Guy)
  20. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    It is REALLY annoying. So much so that I personally think its distracting when backing up. Its a "must disable".
    Lexus uses a controller based program for making these setting changes that used to be called C-BES and is now Lexus Personalized Settings or (LPS). If Toyota is using something like that now the dealer will have to make the changes. Lexus dealers will give you a printout of all the settings and options and then will make however many changes you want one time for free.
