2010 - Help! Disabling Reverse Beep
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by sherryp, May 30, 2009.
  1. Oilpig
    Oilpig New Member
    Houston
    I want to put in a good word for the backup beep!
    I know everybody hates that beep, but I'm one of those increasingly rare people who's other car is a manual shift (a '95 Tacoma). First gear is "up" on the shift, just like reverse in the Prius. When I want to start going forward, I shift up without thinking. If not for that backup beep, I would have run over somebody's grandma by now!
  2. fotomoto
    fotomoto Senior Member
    5,638
    3,813
    So. Texas
    I brought this up before in an unrelated thread and was directed to SEVERAL threads, some over five years old, from folks who also think the electronic shifter is bass-ackwards.
    REVERSE SHOULD BE DOWN!!! There I said it. I feel better.
    :focus: I have purposely avoided completing my new customer satisfaction survey (despite the incessant calls and emails) until I can get that dang blasted beeping canceled.
  3. triscb
    triscb New Member
    23
    Harrisburg, PA
    Took mine to the dealer and they did it for me with the Toyota Scan Tool.
  4. Ted in Olympia
    Ted in Olympia New Member
    84
    Olympia WA
    Went to Toyota yesterday and he told me to pull it right in. Hooked up the laptop and now I only get one beep. They did it for free and included a smile.
    TED
  5. seal2cc
    seal2cc New Member
    52
    Virginia
    ScanGauge II is your friend...for seat belt beeps too if you want.
  6. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I know that the sequence HAS to be P R N D, so if R was down, the P button would have to be below the shifter.
  7. mrdavie
    mrdavie New Member
    No. I think it is so the driver does not forget he or she is in FORWARD when trying to back-up. That's pretty important if you are parked in the garage, it's morning, and you're half asleep. It is so easy to put the car in gear, I appreciate the beeping to remind me I have the car in reverse.
  8. DataWrangler
    DataWrangler Prius Owner (finally!)
    128
    West Houston, Texas
    Took mine to dealer I bought it from ... Asked the sales rep to set the reverse beep to single beep. ... He took it in back (I think he may have even done it himself) was done in no time ... No charge. Must be a dealer thing:confused:
  9. DataWrangler
    128
    West Houston, Texas
    yes yes yes yes yes !!!!!!!!!!
  10. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    The car should have a circle of buttons in the center of the steering wheel, like a '58 Edsel. That'd solve the problem.
  11. darelldd
    6,059
    389
    Northern CA
    So just to make sure I understand correctly: There are two ways to turn off the reverse beep:
    Have the dealer do it for $0 - $93, or use the Scanguage. No other way?
  12. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    For the Gen III, yes. You could DIY on the older models.
  13. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    You could buy a $30 ELM clone off eBay. Plug it into a laptop and run a terminal emulator program. Then issue the command that is documented for the ScanGauge. It's certainly not user friendly, but it is cheap.
  14. darelldd
    6,059
    389
    Northern CA
    Ah... advancement! :sigh: Yes, this was the first thing I did and documented for my 2006. My dad just showed up with his 2010, and I figured no problem! I'll fix that for you... and couldn't. :(
    I think I'd rather buy the ScanGauge... but my dad says his service guys will do it for free, so I think I'll go that route!
    Thanks for the help.
  15. sunvia
    sunvia Junior Member
    67
    palm springs,ca
    Maybe someone could discover where the beepin buzzer is located and disconnect it.... Or possible a fuse that operates the reverse and the seat belt buzzer...
  16. nparker13
    nparker13 Member
    121
    CT
    Anyone else have tips for stubborn dealers? Mine (A1 Toyota in New Haven, CT) refused several times, and I'm getting very frustrated. I like the dealership besides that, but its aggravating.
  17. rleepac
    rleepac New Member
    44
    Manteca, California
    Are there instructions somewhere for how to do this with the ScanGauge II?
  18. dropshot
    dropshot New Member
    28
    My dealer claims it's impossible to disable, I told them they are liars... :mad:
  19. seal2cc
    seal2cc New Member
    52
    Virginia
    SEARCH function is your friend now. There is an XGauge code you enter in the SG and it will do both things, plus can switch it back on if you want.
    Someone has posted all of the XGauge codes for SG II somewhere here on PC. It is VERY EASY, and then you have all the other functions and benefits of the SG. I don't know why people keep beating their heads against the wall with dealing with recalcitrant dealers when this such a no brainer - don't need a svc appt, wait time etc etc. @ $145 on Amazon
    Here are XGauge codes:
    https://spreadsheets.google.com/ccc?key=0AiHL0r_2nhUEdF9lVVBxOVNoN3Zva3E0NmdZTUR1eVE&hl=en#gid=5
    It is from #38 of this thread:
    http://priuschat.com/forums/gen-iii...-4-gauges-do-you-use-your-scangauge-ii-4.html
  20. evpv
    evpv Active Member
    691
    338
    West Coast
    2019 Prius Prime
    Scangauge's are $159.99 on Amazon these days. I wish they were $145.
