2010 Hybrid Battery Advice Needed
Discussion in 'Gen 3 Prius Main Forum' started by Lynde Lu, Jul 28, 2019.
  1. Lynde Lu
    Lynde Lu New Member
    23
    Austin, TX
    Seeking advice on if my hybrid battery is going bad. I have a 2010 with 127k miles, owed it for 4 years with absolutely no issues. While I was driving through the car wash in neutral yesterday my prius started beeping stating the battery was too low and needed to be shifted back to the park position. I'm about to drive 1000+ miles from AZ to TX in about two months and worried my hybrid battery may need to be replaced before the big trip. I'm a little concerned about taking into the dealership since I don't find the dealership here to be entirely trustworthy. Any advice on my next steps or things to keep an eye out for to truly know if my hybrid battery is failing?
  2. bettergolf
    bettergolf Active Member
    495
    370
    Sanford NC
    What, you didn't read the replies from your other thread on this?
    bisco and Grit like this.
  3. prev93
    prev93 Member
    63
    Califon, NJ
    I have noticed my 2010 beeping as well sometimes when I wash it. I'm sure others will weigh in on this, but it may be nothing to worry about especially if the car is running OK and there are no further alerts coming from it.
    Lynde Lu likes this.
  4. Lynde Lu
    Lynde Lu New Member
    23
    Austin, TX
    It's my first thread, I didn't think it went through so I rewrote it 20 minutes later
  5. RicoWolf
    RicoWolf New Member
    Sebring,Fl.
    It could have been an aberration because of the water pressure.If your hybrid battery charges
    up while you are on the Highway and discharges gradually while you are in traffic,and then charges up
    again when you are Highway driving(braking also charges it up a little), then it should be OK. If your car transmission was in
    neutral while you were in the car wash and you had AC on,radio playing,etc.,etc.,the hybrid battery won't charge up. The charge
    could have been very low,thus you received the beeps. Just watch the battery charging monitor and see if it goes up and down
    while driving in the conditions I mentioned. With the mileage on your car,the hybrid battery is not as efficient as it once was,but should be
    functional for awhile depending on your driving,use of AC,etc. I have 112M miles on my 2010 Prius and it is fine,though I don't get the
    mileage I used to get when it was new.
  6. bisco
    52,861
    welcome!
    the carwash problem is not necessarily your problem, but every prius owners problem.
    if the hybrid battery isn't close to full when you enter in neutral, and you have the a/c on, you risk a low battery by the time you come out, and possibly even a no start situation.
    with a 10 year old battery, my best advice is to stay out of car washes that demand neutral
    enjoy your trip.(y)
    Raytheeagle, Lynde Lu and ALS like this.
  7. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    Unless it throws a code that the battery is going bad don't worry about it.
  8. Lynde Lu
    Lynde Lu New Member
    23
    Austin, TX
    Thank you so much!!
  9. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    And then you’ll be the perfect candidate for a grid charger.
    slalomboi and Raytheeagle like this.
