2010 ICE noise
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mimalito, Feb 2, 2020.
  1. Mimalito
    Mimalito Junior Member
    Manchester, CT
    Good day all,
    I've creeped this forum page over the years but have now made an account to seek some guidance.
    I own a 2010 base model. I am the second owner and have had it since 2015. The car has just under 188k miles and has been driven from CA to CO and now to CT. I've been fortunate that the most I've ever had to put into it has been new tires. I had a hybrid system failure about 2 years ago but luckily was a known recall issue and was repaired for free. It's always been a quiet and reliable ride.
    I'm not very mechanically inclined so I'm not sure what my next steps should be. My wife and I share the car and during the holiday season it was up for an oil change. I wasn't able to get it in anywhere due to our tight schedules. I did top it off with a few quarts of oil. I figured even if the filter/oil needed changing that oil in was better then no oil. Again.. I'm not really a car person and it seemed to be the best alternative in our situation.
    A few weeks ago my wife texted from work to say the car was acting /sounding really weird. She was worried about getting home but drove it anyway (16 miles) back home.
    When she got home I went out and listened. Sure enough the car now makes a terrible knocking sound from the ICE. We assumed it maybe had something to do with low oil. She had reported that the oil indicator had come on occasionally when making sharp turns. I drove it down the street to a small auto shop. They checked the oil and reported it had none. They put a small amount in before taking it into the shop. When I started the engine and they heard it they told me he engine was probably shot and no oil change was gonna fix it. They didn't do any real diagnostic work beyond listening to it for a minute.
    I'm at a loss about what to do. I thought I'd be able to drive this car longer. I've been fortunate to not have any major issues (until now). It's our only vehicle as a family. I'd like to keep it.
    Any suggestions?
    Can anyone point me towards a specialized mechanic in CT?
    Help me Obi "Priuschat" Kenobi... You're my only hope
  2. Mimalito
    Manchester, CT
  3. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    @nudriver just had this and said it’s not oil related, let’s get his take on it.
  4. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    No check engine light? That's a good sign. The rhythm sounds like bad valves tapping, except louder. A heavier weight of oil can certainly cause that to happen, it would be a case of oil starvation if they added conventional 10w30 oil just to get the car going again. I would withhold pronouncing a death sentence until you dump the oil and replace it with a new oil filter and fresh synthetic 0W-20. You may get lucky. Otherwise, the usual next step would be a simple compression check to see if all cylinders are holding the proper pressure and are within 20% of each other. Good luck, and give us an update if you don't mind.
    Mimalito likes this.
  5. Leadfoot J. McCoalroller
    8,275
    7,780
    Pennsylvania
    2018 Prius c
    Sure sounds like a rod knock.
    Tim Jones and vlxerdon like this.
  6. Mimalito
    Manchester, CT
    No check engine light. Nothing out of the ordinary on the dash. It made that sound both before and after the oil they put in. I don't know what type they did though. I usually do the suggested synthetic during my changes. I know no one here can say with certain but I'm guessing I should have it towed to a shop for a change? I'm very nervous about driving it anywhere.
  7. JC91006
    16,936
    8,646
    How did you determine the car needed a few quarts of oil? How many did you put in? Did you check the oil level after you filled it?
    Raytheeagle likes this.
  8. Mimalito
    Manchester, CT
    Message on the dash about low oil. I believe I added 2. Then I checked the dipstick and it was registering. The message went away.
  9. bisco
    52,803
    Start shopping for a new car
  10. Mimalito
    Manchester, CT
    I wish it was that easy. We're certainly looking but I unfortunately lost my job late November so affording or financing a new vehicle is proving difficult. I was hoping that with our tax return I might be able to find a fix or have someone at leadt look at this car.
  11. Nor'easter
    Nor'easter Member
    158
    96
    New Hampshire
    "Rod Knock", btw, means your engine is toast. It's the noise your engine makes when the main and rod end bearings have been trashed due to operating without oil pressure.
    #11 Nor'easter, Feb 2, 2020
  12. vlxerdon
    vlxerdon Junior Member
    Georgia
    Been working on cars since I was 14 years old. That is a rod knock. No oil change is going to fix that,sorry.
  13. bisco
    52,803
    if you confirm the worst, you can shop around for someone who will put in a salvage engine for a couple thousand, but idk how much it's worth investing in a 10 year old car with almost 200k on her.
  14. Mimalito
    Manchester, CT
    I'm thankful for all the information everyone has given me from the somewhat positive to the truly grim. I may still have it towed somewhere for a full oil/filter change. I know it may not do anything for me but it's maybe $30. Maybe I'll be surprised?
    I had started to look at salvage engines on allusedparts. It looks like $1800-$2500(plus labor) for an engine with 90-115k miles on it. I'm curious on people's thoughts about getting an engine to be installed. Bisco you mention it might not be worth it for a car with nearly 200k on it already. Is your thought that the rest of the car and it's components are at nearly 200k even if a new engine is installed?
    Also if the issue is the "rod knock" that others have mentioned is replacing the entire ICE the only way (cheapest way) to fix that? Or can that individual issue within the engine be repaired for less?
    I unfortunately still owe on this car. I'm in the last year of a very long loan. Worst case if it's junk I guess I'll continue to pay it off and sell it for junk once I own it.
  15. Mendel Leisk
    42,296
    #15 Mendel Leisk, Feb 3, 2020
    bisco and dig4dirt like this.
  16. Frank1234
    Frank1234 Member
    187
    83
    Indianapolis
    Well certainly it’s tough to drop to much money in a car with almost 188k Toyota it’s well known by been capable of going hundreds thousands more than that with proper maintenance, I believe if you confirm that you need a new engine it’s ok to replace it if you not planning selling it or upgrading it soon after, otherwise you better off using that money for another car, and sell the car that needs repair as it for the money you still owns on the car, maybe more or less depending on the car value.
    #16 Frank1234, Feb 3, 2020
    Tim Jones likes this.
  17. Tim Jones
    Tim Jones Senior Member
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    Another oil burner...... if you drive regularly check your oil once a week..... especially after 150,000
    Frank1234 likes this.
  18. Tim Jones
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    And the Traction battery might be fixin to go out.....
  19. Mimalito
    Manchester, CT
    I'm learning a lot here and appreciate all the info. It seems like this car is most likely toast. I'm curious if any users in my general area are familiar with a reputable shop in Hartford County, CT? I think I'd like to take it in for a hands on diagnosis from someone who knows these cars. Last time I went to a dealership shop I didn't have a good experience. I guess they are a last option. At this point I'd probably rather not put $2-3k into a car that might.. Might be worth $5k. I was gonna drive it until I couldn't, I just thought I had more time. And I guess I would have if I had been more vigilant.
    Mendel Leisk and Frank1234 like this.
  20. Leadfoot J. McCoalroller
    8,275
    7,780
    Pennsylvania
    2018 Prius c
    Technically yes, but it's not even remotely economical unless you are doing 100% of the labor yourself, and it does require a skilled touch.
    Practically speaking no, it's not worth it at all. By the time one rod bearing has burned that badly the others are close behind.
    Given age & mileage this car is a high risk for a couple of other expensive problems.
    I think the very best thing you could do is unload this car for something simpler. Gas prices simply aren't high enough to make a used hybrid into a good deal given the risk of expensive repairs. I wish I had more appealing advice, sorry.
    Don't take this car to a dealer, they'll see you coming a mile away. They will correctly conclude that you need a new car and do everything they can to supply it. You won't have any leverage.
    It's generally a bad idea to take any car back to the brand dealer once said car is out of warranty. The cost of service is usually much higher than you'd get from an independent.
    I once knew a great mechanic down around Farmington but I can't find any evidence he's still in business. Operated out of a garage on the edge of Robertson airport. Quiet, cash-only kind of guy. Wouldn't shock me if he's still there but not in any search result. He was a local legend.
    #20 Leadfoot J. McCoalroller, Feb 3, 2020
    Frank1234 and dig4dirt like this.
