2010 idles rough
Discussion in 'Gen 3 Prius Main Forum' started by Giff57, Jul 5, 2025.
  1. Giff57
    Giff57 Junior Member
    iowa
    After new plugs, new intake manifold, egr and egr cooler. Prius idles rough. Got EGR low flow code after highway drive. She runs ok down the road. Very rough at idle. I’m thinking vacuum leak, but where? Any help appreciated
  2. bettergolf
    bettergolf Active Member
    495
    370
    Sanford NC
    Uh Oh...here they come!
    Grit and Brian1954 like this.
    52,863
    how many miles on her?
  4. Giff57
    iowa
  5. bisco
    52,863
    Were the plugs oem from a dealer?
  6. ETC(SS)
    7,569
    Need some more deets.
    Who did the work?
    NEW intake manifold? o_O how the heck did you wear out the OLD intake manifold??
    See also: EGR/EGR Cooler......
    Yeah...there's something going on.
    Make sure you (or somebody else) didn't miss something on the re-assembly.
    Also...check and maybe clean your mass air flow sensor.
    Coolant level....
    Dipstick....
  7. Mendel Leisk
    42,355
    And you as well. :)
    bettergolf likes this.
  8. Mendel Leisk
    42,355
    @Giff57
    How long have you had it?
    Is engine coolant level in the reservoir stable?
  9. ChapmanF
    19,037
    Vacuum leak is plausible. It would otherwise be very difficult to explain a low EGR flow code (I assume you mean P0401 ... for clarity, I advise everyone to include the actual codes in posts, not just paraphrases) right after putting on new or freshly cleaned EGR components.
    But the car measures the EGR flow by comparing the vacuum without EGR to the vacuum with EGR, so if there is some leak reducing the vacuum without EGR, then that can make the EGR flow measurement come out artificially bad.
    There are a few vacuum connections to the manifold that would all have been disturbed in the work that was done, so I'd certainly start looking at those.
