2010 Intermittent Vibration
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by chryguy, Jun 30, 2019.
  1. chryguy
    chryguy Junior Member
    Joliet,IL
    I searched first, found nothing that matches exactly, so here I go.
    My daughter lives 12 hrs away, so I have to work on her car long distance.
    Her Prius currently has 178K on it, and the Car has a pronounced intermittent vibration. When visiting her I've driven and ridden in it while it has happened.
    It's happened at speed (60-70 mph), and in a parking lot at under 10 mph.
    It has been going on for months (maybe 6 months).
    After a couple months it finally threw a code (misfire on cyl 4) so we had all the stick coils and plugs replaced...still vibrated.
    Having been in it when it vibrated, I took an expensive guess and had her replace both front axles (and the output shaft seals).
    It still vibrates.
    Since it's intermittent, it's hard to give to a shop for diagnosis.
    Also when it vibrates it's very apparent.
    Could it be something in the hybrid drive? Are there any universal joints in the system besides the axles?
    I'd appreciate any ideas.
    Thanks in advance
  2. chryguy
    Joliet,IL
    Did I put this in the wrong area?
    52,855
    just report your post and ask a mod to move it to gen2
    at 10mph, does it do it with engine on or off?
  4. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    The title states it's a 2010 so I guess this is the correct section.
    Reading from your descriptions, you are driving at light throttle conditions (60-70 or 10 mph). Vibrations maybe coming from pre-ignitions/pinging, if that's the case, I here list some possible causes:
    *Low quality gas
    *Carbon filled combustion chambers
    *Dirty fuel injectors
    *Clogged ERG passages
    Least expensive way to test is try a tank of 91 octane gasoline when gas tank nears empty. (Since you will need gas anyways) Observe if the symptoms goes away. Also try a bottle of fuel system cleaner into the gas tank.
    Does your daughter's Prius burn motor oil?
    Raytheeagle likes this.
  5. chryguy
    Joliet,IL
    Eventually it turned on a CE light.
    It was missing on 1 or more cylinders. Replaced all the coils and plugs and it ran well for 18 months or so.
    The replacement coils were Denso.
    So, the update to that story is it started missing again.
    Replaced the coils and plugs again(no reasonably priced Denso coils available). Stopped the missing for a few months.
    Started the intermittent Missing again.
    Code thrown was P0172 for "System too Rich Bank 1". She was advised to replace the injectors. Had them replaced and it stopped missing.
    700 miles or so later it starts stumbling/missing again.
    Running smoothly for long periods with intermittent stumbling.
    That slowly changed to running like garbage most of the time.
    It is currently throwing these codes,
    P0172 System Too Rich Bank 1
    P0300 Random Multiple Cylinder Misfire
    P0301 Cylinder 1 Misfire Detected
    Does anybody have any experience with this set of codes together?
    Any ideas, or things to look at?
    Thank you
  6. ChapmanF
    19,025
    I would probably work down the troubleshooting tree for the P0172. The misfire codes are probably symptoms.
