2010 JBL Navigation E7022 Wiring Diagram To Test Power
Discussion in 'Gen 3 Prius Audio and Electronics' started by thelostraver1, Aug 11, 2021.
  1. thelostraver1
    thelostraver1 New Member
    Las Vegas NV
    Hello all,
    I have a Navigation radio removed from a 2010 Prius. JBL E7022, Toyota part # 86120-47390. I can't seem to find a wiring diagram to locate power and ground to bench test this to make sure it works.
    Can anyone help?
    Thanks
    Kevin
  2. ChapmanF
    19,002
    Well, you're welcome to my hastily typed-up notes from one day when I was looking in the wiring diagram. Looks like I wrote them in a [number][circuit]=[color] format, which would mean connector L37 position 2 is the CANH circuit and green, position 3 is CANL and white, and so on. Circuits you could care about for power purposes include B, ACC, and IG, and of course GND. Notes like (nxt 3) or (prv 2) I added on shield drain connections to indicate which circuits run in that shield.
    Code:
    ? L36 90980-10859 2.3 II m antenna amp
    A L37 90980-12404 0.64 II f
      2CANH=G 3CANL=W
      5SNS2=B 18SGND(nxt 3) 17MACC=R 19MIN+=B 20MIN-=W (mic)
      21CGND(nxt 3) 22V+=R 23V-=B 24CA+=W (camera)
    B L38 \__ component    90980-12552
    C L39 /   tuner        90980-12012
    D L40 90980-12038 1.0 III f / 2.3 II f
      1B=SB 2ILL+=G 11ACC=GR 12ILL-=W-B 13ANT=BE 20GND=BR
      5ATX+=G 15ATX-=R 10SLD(nxt 4) 8R+=G 18R-=B 9L+=R 19L-=W 7MUTE=B
    E L41 90980-12460 0.64 II f
      7SW1=R 8SW2=G (steering switches)
      11IVO+=Y 12IVO-=BR 13SLD(prv 2)
      15ARI=B 16ASGN=W 17ALI=R 18AGND(prv 3) 19AUXI=W
      9TX1+=LG 10TX1-=P (parking assist ECU?)
    F L42 90980-11909 1.0 III f
      1PKB=R 2IG=B 3SPD=V 5REV=P
    G L45 90980-12551
    MAX2, Stephen Frost and rajul.urvashi like this.
  3. thelostraver1
    Las Vegas NV
    Appreciate the help but I still don't understand which two wires I need for 12v / ACC and ground. I can't decode it.
  4. rajul.urvashi
    rajul.urvashi Junior Member
    Reston
    Thanks for your good work. I am in a different situation, I am installing an aftermarket head unit. ( Long Story Short) I am finding RL+ RL- RR+ and RR-. Can you tell me which one has it. I tried to find in L40 but no luck.
  5. ChapmanF
    19,002
    I haven't poked at that in a long time, but this is the JBL system with the separate amp. It might be that the R and L pairs shown above (8,18 and 9,19) are all that goes from the head unit to the amp (besides the 5,15 AVC-LAN pair).
