2010 knocking after sitting
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by monahj, Aug 18, 2018.
  1. monahj
    monahj Junior Member
    25
    16
    Hyannis, ma
    Hello, it's been awhile since my last post. Car currently has 246000 and has been serviced regularly and has been problem free until recently. The engine would knock when starting up after sitting for more than 3 hours. Oil is synthetic and is at the right full level, no leaks. Dealer codes P0301, P0302 and P0304. Dealer replaced EGR valve and gaskets, performed software update and changed PCV valve as well.
    Car sat overnight and would knock(rattle) on start up, but would not rattle on start up as long as the car is started without sitting for more than 3 hours. The longer the car sits, the harder the knock. Currently have only one code P0300 misfire detected - permanent. Toyota mechanic is unsure of the issue because the manual indicates to change EGR to solve the issue.
  2. JC91006
    16,931
    8,640
    Changing the EGR may do it
    monahj and m.wynn like this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    The mechanic will have to go outside of the manual, as the egr cooler and intake manifold are most likely plugged:(.
    How much oil does your Prius consume?
    Has the egr circuit been cleaned?
    Is the engine coolant level stable?
    Good luck and keep us posted (y).
  4. monahj
    25
    16
    Hyannis, ma
    EDR was changed
    Burns no oil.
    Unsure if mechanic cleaned the EGR circuit.
    Coolant level is stable, Just did the coolant service last month at 240000 for engine and invertor.
    Raytheeagle likes this.
  5. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    My bet is they just did the egr valve and did nothing else:(.
    You could pull the egr pipe and see the condition, but the intake manifold and egr cooler will be severely plugged;).
    When you attempt this service, look for an independent mechanic as the dealer will not take this job on. Might want to look for a spare egr cooler as the one that gets pulled will be coked up and will take time to clean.
    Mendel Leisk, RMB, monahj and 2 others like this.
  6. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    As Raytheeagle sugguested, please do yourself a favor by cleaning the egr cooler/pipe/intake manifold to save the head gasket, and do it ASAP. I hope the knocking has not damage the head gasket yet.
    Best of luck! (y)
    monahj and Raytheeagle like this.
  7. Mendel Leisk
    42,248
    The EGR cooler is the gold mine.
    RMB, monahj and Raytheeagle like this.
  8. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    Probably the head gasket has started to leak
    That is why when sitting for more time it knocks. Probably some fluid leaking in one cylinder a bit. Check missing coolant
    Could be also an injector leaking
    monahj, bisco and Lightning Racer like this.
  9. TampaPrius.com
    TampaPrius.com Active Member
    461
    300
    Tampa, Florida
    Do compression check. Most likely head gasket.
    bisco, monahj and 4est like this.
  10. Mendel Leisk
    42,248
    This got me looking through the repair manual. Found the compression test instruction, and be forewarned: it does use Techstream. Not sure if there's a work-around for that.
    But also, casting fore and aft a few pages found various other inspection procedures, so "printed" a compilation of all. The compression test is in there:
  11. monahj
    25
    16
    Hyannis, ma
    Thank you for all your replies. I will have the mechanic clean the cooler as well as do a compression check.
    All the fluid levels are at the right level, oil and coolant. No leaks.
    I did try a test I saw on another post: press start twice with no brake, Press a third time with the brake pedal and the vehicle started without knocking(rattling) Car has sat for 18 hours. Could the problem be fuel related? Unsure how from sitting it effects the knocking? Thanks
  12. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    To see am injector leek you have to remove or and test it
    However I still think it's the head gasket
    monahj likes this.
  13. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    The workaround I did when I was diagnosing mine was this. Remove all coils and plugs. Install tester in cylinder. Put car in Ready mode and push down accelerator. The resulting spin up of engine will satisfy the requirements of test. I had 190 psi across the cylinders after my bent valve got replaced.
    monahj and Mendel Leisk like this.
  14. Mendel Leisk
    42,248
    What about disconnecting the injector leads, avoid a gas wash? Or would that prevent the car going into Ready?
    monahj likes this.
  15. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    No longer then it takes to get a reading, I didn’t worry about it. But that’s a great idea.
  16. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    When the car is hot, the deposits on the intake are softer. But as the car cools, these deposits harden, and it’s more difficult for the engine to pull in the fuel/air. There are some fairly small inlets in the intake manifold which can partially or fully clog with deposits.
    This is why I would begin by cleaning out the EGR pipe and the intake manifold. You need to use new gaskets when you do these tasks! These are fairly simple tasks. The EGR and EGR cooler are more difficult. While you have the intake manifold off, it’s very easy to replace the PCV valve, so do that at the same time.
    By way of explanation: Fuel and air enter your engine through the intake manifold. But in addition, pressure which builds inside the engine is vented into the intake manifold, so that it can be burned instead of vented to the atmosphere. That’s what the PCV valve does, but it can also let oil enter the engine, which can cause deposits and other problems. In addition, some of your engine’s exhaust gases are routed back into the engine to be burned, and that’s what the EGR valve does. So a problem with the PCV or the EGR, and time itself, will gradually clog the intake manifold.
    #16 Rebound, Aug 20, 2018
  17. Mendel Leisk
    42,248
    I agree with most everything, but when I went through these chores, albeit with only a bit over 70K kms, I didn't change any gaskets. They all looked very good, still very pliant. But yeah, maybe better to be safe, who knows.
    monahj, RMB and Raytheeagle like this.
  18. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Round 1 I had new gaskets, round 2 I went with what was there;).
    Round 3, might just keep everything the same too(y).
    monahj, RMB and Mendel Leisk like this.
  19. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    To each their own, but OP has 246k miles on his Prius, I would assume the intake manifold gasket will need to be replaced once opened up for cleaning.:p
  20. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    I’d have a spare set around just in case;).
    The elastomeric material that is used for the gasket does not take a set very easily, probably even over 246k miles i’d bet:).
    But life does favor the prepared (y).
