2010 Lexus Hybrid
Discussion in 'Gen 3 Prius Main Forum' started by spwolf, Sep 11, 2008.
  1. Tideland Prius
    16,668
    Nice info. spwolf, how come you haven't posted it on CL?
  2. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    thats where it was removed from, and you know they dont do that unless someone higher up requested it :)
  3. Tideland Prius
    16,668
  4. asus
    asus New Member
    Ann Arbor, MI
    Makes you wonder what a 4cyl IS250-like car would get, even without the hybrid. Probably above 30...
  5. wchardin
    wchardin Senior Member
    2,055
    Nashville, TN
    I would like an IS hybrid. I had a IS250 which delivered 26 mpg. It was a great car, but not a very spacious car. I love the room that I have in the Prius.
  6. Tideland Prius
    16,668
    Heck, use the 2.5 litre V6 with HSD. It'll be quite fuel efficient (it is a small v6 after all)
  7. PriusSport
    PriusSport senior member
    1,498
    88
    SE PA
    I suspect 50 mpg or so is close to what you are going to get with any hybrid coming out the next couple of years. The current Prius is probably as fuel efficient an ICE/battery car is going to get. The next quantum step will be a complete (or near complete) battery car.
  8. spwolf
    3,156
    440
    Eastern Europe
    you dont need it... with FWD based vehicle, you get more space, its less expensive, more efficient... as original said, they are working hard to get to 40 mpg with 4cly...
  9. Tideland Prius
    16,668
    true but if they ever one want ES350h, the 3GR works fine but it seems they want an ES450h.
  10. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    My bet is the brandnew 2.5L 2AR-FE I4 engine is more efficient than the 2.5L 4GR-FSE V6.
    Ken@Japan
  11. Tideland Prius
    16,668
    Probably and with decent power if they direct injection it. (179hp without on the RAV4). I think it's just a stigma thing that you can't have anything smaller than a V6 but I do think some Lexus folks are rooting for a 4 cylinder hybrid.
  12. spwolf
    3,156
    440
    Eastern Europe
    i dont think there will be direct injection in AR engines - Valvematic version have more power and economy than previous AZ with direct injection, so I am pretty sure they will be using Valvematic instead of D4 in the future for 4cly engines...
  13. REGENR8
    REGENR8 New Member
    Calif
    The information I've seen, it that the model is to be named the HS250h.
  14. Tideland Prius
    16,668
    HS... so sedan, not hatchback? but the Prius will be a hatchback..... hmm...
  15. wchardin
    2,055
    Nashville, TN
    Does HS stand for Hybrid Sedan or Hybrid System?
  16. Tideland Prius
    16,668
    Good point. I assumed sedan. Guess it was a bad assumption.
  17. wchardin
    2,055
    Nashville, TN
    Yeah, I'm not for sure if its for sedan or system. I thought that the HS250h sounds redundant, but I guess I'm not in charge of those decisions. ;)
  18. Tideland Prius
    16,668
    Probably for consistency.
  19. lndshrk
    lndshrk New Member
    Utah
    Why do we assume that the H in HS means "Hybrid".
    You have ES, GS, IS, and LS - all sedans - all "different form factor"
    You have SC - a coupe
    You have GX, LX, RX - all SUV's
    So.. the HS will be a sedan - aka 4 doors.
    My bet - a station wagon-esque hybrid utility sedan.
    4 doors + a rear hatch.;)
  20. Tideland Prius
    16,668
    What else would the H be?
    ES - Executive Sedan
    IS - Intelligent Sport
    GS - GranSport
    LS - Luxury Sedan
    You're speculating it'll be along the lines of an IS300 SportCross? Would it work again this time around?
