2010 Liftback Leak
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jdcollins5, Sep 16, 2017.
  1. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    image.jpeg image.jpeg After a couple of days of heavy rain after rain bands from Irma, I noticed a stream of water running down inside the car, from the top of the Liftback, when making a turn. I checked the rubber gasket all of the way around without seeing a problem.
    The next morning the same thing happened. This time I noticed a water droplet in the break in the plastic molding around the top of the inside. I popped off the molding and noticed a water droplet around the windshield washer sprayer nozzle. Then I noticed that the clip on the right side of the sprayer nozzle was not engaged. I could push the nozzle up on the right side and see daylight.
    I took a small screwdriver and pulled the clip back out on the right side and secured the nozzle. I sprayed a water hose directly at the nozzle and all around the top of the Liftback and everything remained dry. I need another hard rain to verify no more leaks.
    The first picture shows the top plastic trim removed and the second picture shows a closeup of the nozzle where you can see the plastic clips that holds the nozzle in place.
    I have no idea how the clip became disengaged.
    #1 jdcollins5, Sep 16, 2017
    kc410, Mendel Leisk and bisco like this.
    52,904
    good catch, haven't seen that one before.
    jdcollins5 likes this.
  3. jdcollins5
    5,131
    1,346
    Wilmington, NC
    We had a thunderstorm this afternoon with heavy, driving rain. Everything was dry around the washer nozzle.
    So I think I can declare success on this and consider myself lucky it was a simple problem to fix.
    Raytheeagle and bisco like this.
