2010 MFD Goes Dark When Headlights Go On
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Indy John, Jan 3, 2020.
  1. Indy John
    Indy John Member
    75
    33
    Indianapolis
    Haven't driven at night for a while, and when I turned the parking lights and/or headlights on last night the MFD and other "dash" lights went dark. Only the "Ready" light and seat belt reminder stayed on. Headlights and parking lights off, they came back. With headlights on, I checked that all bulbs were lit. No codes showing and the 12-volt battery tests 12.8 volts, 375 CCA, and 100% life. Any thoughts?
  2. Mendel Leisk
    42,254
    The dash lights are supposed to dim, by design, when the headlights are turned on. I think. Try playing with the brightness dial, low, to the left of steering wheel.
    Threej, pjksr02, scona and 3 others like this.
  3. iskoos
    iskoos Active Member
    415
    254
    Orlando, FL
    I would second what Mendel said above. The same happened to me once and I panicked. It was the brightness dial.
    And once I put some paper document on dash and moved it forward so it doesn't slide off while driving. I lost the left screen. I realized the paper I placed blocked the projection(or maybe reflection would be the right word):).
  4. Indy John
    Indy John Member
    75
    33
    Indianapolis
    Thanks, but they go dark/off/disappear completely, not just dim. Dimmer dial doesn't bring them back.
  5. Mendel Leisk
    42,254
  6. AzWxGuy
    AzWxGuy Weather Guy
    1,078
    558
    Tucson, AZ
    2021 Prius
    In consideration of the 10 years of dust that may have accumulated in the potentiometer, I would try several full-range manipulations of the dimmer dial making sure to move through the clicks at either end of the range. I might personally go as far as spraying some contact cleaner into the dial, but this might not be good for the various plastics in there. Failing this, maybe a fuse?
    ASRDogman likes this.
  7. ASRDogman
    ASRDogman Senior Member
    8,039
    4,074
    If you turn the all the way ON, past the little bump you feel, the display will be at full brightness,
    as it is during day driving. If you go just past the bump, when you turn the lights on the display will be dimmer.
  8. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    Definitely something in the dimmer circuit.
