2010 "Miles to Empty" Accuracy
Discussion in 'Gen 3 Prius Main Forum' started by eglmainz, Jun 14, 2009.
  1. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    I sort of think of this the same way I look at the milk in the fridge. With two daughters a gallon of milk may last 2 days, a week, or anything in between. If we have less than a half gallon and it is convenient I'll pick up another. With gas anytime I have 4 or less pips I'll stop if it is convenient and cheep. Sure I may have an extra stop or two at the gas station every few months, but it is never a problem. Same goes for the milk - I avoid the hissy-fits in the morning - either for a daughter that needs milk for cereal or a wife needing it for coffee.
  2. richard schumacher
    7,682
    1,064
    United States
    Yes, at least two:
    - It can damage the fuel tank management sensors and valves. This can shut down the car and cost hundreds to fix. Search the site for posts by Prius tech Galaxee for some sob stories.
    - It saturates the vapor recovery canister, which increases air pollution. Did we pay extra for a Prius to increase air pollution?
    Topping-off is really oldschool. Don't do it.
  3. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    I have driven until the "miles until empty" reads 0 miles and the last pip on the gas gauge blinks a few times. If I fill it at about that point it will take about 10 gallons.
    Although I don't make a habit of it I think I can safely go at least 50 miles after it indicates 0 miles to go.
    After Bob Wilson's tests I don't want to run out of gas but if I do the important thing is to pull over and shut the car down as soon as possible. As to the other things, I have violated all those "don't run low on fuel" rules a time or two and nothing bad has happened because of it, at least not yet.
  4. FLteacher
    FLteacher Junior Member
    75
    I just traded in an '02 Sonata that I'd topped off too many times. The charcoal canister that absorbs the gas fumes was ruined (a $600+ fix) and I was at the point of it taking about 15 minutes to put about 10 gallons of gas in. The pump would shut off after .6 gal. and I would have to wait at least 15 more sec. to put in another .6 gal. This seriously cured me of ever topping off again.
  5. Tideland Prius
    16,658
    Just came back from a trip. I drove for about 70km on the blinking pip on the highway. The DTE read 15km. I refuelled with 39 litres which worked out mathematically (I did a calculation before we left for the trip to see if I could do it in one tank and I expected to run on the blinking pip for a while).
    Trip was 768km round trip. I know the Gen 2 does 5.1L/100km at 70mph. I also know the Gen 3 is a little bit better at those speeds so I rounded down to 5.0L/100km. I know the blinking pip comes on when there's 10 litres left so that would make it 35 useable litres before the low fuel light. That means I can do 700km and I would be running on the blinking pip for 68km. It was pretty spot on. (The MFD showed 4.6L/100km but calculated by hand, I got 5.03L/100km)
  6. lig13
    lig13 Junior Member
    17
    New Hampshire
    In most cars, there are two things you do NOT want to do. Trying to put TOO MUCH gas in it will cause flooding of the evap system from overflow, damaging the charcoal canister (very expensive part for most cars).
    Letting the gas run TOO LOW may cause two problems. The fact that you may have excess crud accumulated suck into the pump (mentioned previously). More importantly it can burn out/shorten the life of your fuel pump (very expensive job in most cars). Most fuel pumps depend on the fuel as a "coolant" to draw heat away. No, it's not THAT hot, but hot enough that if the pump runs while dry, it can damage the bearing(s) and/or impeller either permanently, or enough to shorten the overall life of the pump.
  7. JJB
    JJB New Member
    39
    Alpharetta, GA
    I noticed the DTE drops quickly as it approaches 0. I was driving home one evening, with the last pip flashing- it said 15 miles to empty. About 5 miles later it hit 0. Fortunately, after it hit 0, I was able to drive 5 miles back to the gas station the next morning.
  8. fuzzy1
    10,663
    The several times I tried it and watched DTE, it didn't seem to count all the way down to zero. Somewhere between 5 and 10, it tended to snap to zero.
  9. vday
    vday Member
    312
    Israel
    I have had the same experience the couple of times i went low :)
  10. rebenson
    rebenson Member
    364
    43
    Suburb of Chicago
    just filled up my car and I had 80 miles to empty indicated. went a little over 450 miles (2 lines) I put 8.35 gallons and my tank is supposed to be 11.9 capacity.
    Since I traveled over 450 miles on 8.35 gallons, I would think I would be able to get at least 175 miles on 3.55 gallons left.
  11. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    Hi patsparks, I've only had my prius 2010 since july 2010. I live in country Vic and run my daughter to elite soccer training in Melbourne 4 times a week. round trip of approx 400k. about to clock up 80,000ks. have learned to ignore the bip and flashing bar. I can safely run another 160ks. most fill-up I've had is 42 ltrs.
    i generally average about 4.8l/100ks. best is 4.2.
  12. Canard
    Canard Member
    223
    Ontario, Canada
    45 L tank, right?
    I'm comfortable running down to 0 km remaining on the Distance-to-Empty indicator. When I do that and fill up shortly therafter, it's almost always 36 L that I'm putting in. That's 9 L remaining in the tank...
    4.5 L/100 km with 9 L equals another 200 km before I run out.
    -Iain
  13. RRxing
    RRxing Senior Member
    2,559
    1,834
    NEPA
    All PIPs are not created equal. Here's the data for the 2010:
    I got the liter info from the repair manual, then did the conversion to gallons. The data is for when the PIPs normally come ON, so I won't say for certain if the ranges hold for when the PIPs go OFF.
    Personally, I'm not convinced that waiting until the last pip starts flashing before refueling has any real, lasting value. I usually fill up around 2-3 pips and go my merry way. Miles Per Gallon is more important to me than Miles Per Tank.
    (BTW, I think the mods should consolidate all of the fuel tank/gauge/pip threads, or make it a sticky. I just posted the above chart on the Gen II forum, where there are multiple fuel threads, just as there are here on the Gen III forums.)
  14. Lsegovic
    Lsegovic New Member
    78
    I have been doing experiments on/off with the DTE mileage I found that always starts blinking between 20 to 22 miles to empty and the further I have got after "0"'miles DTE is 40 miles before chickened out. I always drive almost to "0" and pump 9.7 gallons of fuel! so there is like 2 gallons left on reserve always consistent!
    hope this info helps
  15. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    My results have been about the same, although I have gotten as low as 18 miles DTE at the start of blinking. Driving at a steady speed in a straight line lets you get a bit further before the blinking starts. I have also had it start blinking at somethng over 30 miles when turning on a steep hill. Usually I am within a mile or 2 of 20 miles when it starts blinking.
    My fill-up at 0 miles DTE is usually very close to 9.7 gallons
  16. Tideland Prius
    16,658
    Yup. Toyota lights up the Low Fuel light when there's 10 litres left in the tank. I've gone 130km each time after the light goes on and filled around 41 litres. (MID was indicating 4.0 and 4.1L/100km for each of the two tanks)
  17. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    I always set my second trip when the blinking comes on. knowing you have 2+ gal, I run it past 70 miles, then start thinking about getting gas at some point.
    I've pumped 11.8 once (120 miles on blink - but was coasting into the station) - at 70 past blink, you're looking at typically 10.5 gal...
  18. peirhead
    peirhead Junior Member
    48
    PEI Canada
    Tideland I just ran mine till the display read 0 to Empty the other day and there were 8 litres in the tank...so my experience bears out your results, I figure I could have gone another 100Km easy.
  19. Tideland Prius
    16,658
    Good to know it's consistent between cars too. I did two more runs (both were record tanks of 950.2 and 955.1km) and both times I ran for 120km after the blinking light and It only pumped 41 litres so I probably could've hit the 1,000km mark. Darn!
    (Oh and the 950 record was done in the city and the 955 record was done on the hwy through the Rockies)
  20. Slovewell
    Slovewell New Member
    95
    Va
    I didn't read every post but there are some mechanics that claim you could prematurely kill your fuel pump by running your fuel too low. The gas suppsedly keeps the pump cool and can help make it last longer. I heard it is recommended that drivers should fill up no lower than 1/4 tank.
