2010 minimum heat selection is 65 any other years with a lower option?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by 04priusnow, Dec 29, 2018.
  1. 04priusnow
    04priusnow Active Member
    345
    201
    As title says 2010 minimum heat selection is 65 any other years with a lower option?
    65 is way to warm. I find myself constantly switching between low and 65. I have a 2010 model 3. Is this standard for all years/models or is there some cooler options? My hose thermostat only sees above 64 if it's summer or warm outside.lol
    PH-1 ?
    51,109
    65 across all models and years. i just fit the fan on/off when outside temps dictate. it is not a good system
    Mendel Leisk and Grit like this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    Where are you at that 65 is too warm:whistle:?
  4. Grit
    Grit Senior Member
    6,444
    4,185
    Wilkes Land
    In that situation, I would keep temp to "low" and just lower fan speed by pressing down arrow to have to less air hot entering cabin.
    Mendel Leisk and Raytheeagle like this.
  5. ChapmanF
    17,276
    Techstream exposes an option to set an offset (of, I don't know, a few degrees max) to what the car actually thinks the setpoint temperature, or the actual cabin temperature, is. (I don't know why features like this are common; when installing my home thermostat, I noticed it also has hidden "installer options" to do the same thing. Maybe something the dealer can tweak to mollify somebody's difficult in-law who insists the temperature isn't really what it is....)
    So, you won't be able to get the setpoint below 65 on the display, but you might be able to set it to mean something a bit lower (and even more if you also offset the actual cabin temperature to read high).
    I guess that could also create different kinds of passenger confusion down the road, if you don't remember having done it. :)
  6. 04priusnow
    345
    201
    nice find. I haven't played with techstream in years since disabling that backup beep.. will need to look into tomorrow. You could be my winter hero!
    PH-1 ?
  7. 04priusnow
    345
    201
    alright changed ambient to -3C which is the max value for adjustment. Can't wait to try it out in the morning.
    PH-1 ?
  8. 04priusnow
    345
    201
    well not sure what that does.. in monitoring you can see the set temperature setting and ambient adjustment also room temperature. thoughts?
    PH-1 ?
  9. ChapmanF
    17,276
    Shoot, is ambient the only one that's adjustable? That won't do you any good. I thought there were offsets available for the setpoint, or cabin temp, or both.
  10. 04priusnow
    345
    201
    the only settings relative to temp was under Air conditioning. there were 2 adjustment about ambient temp
    PH-1 ?
