2010 MPG Stats - Post Them Here
Discussion in 'Gen 3 Prius Fuel Economy' started by BH1973, May 27, 2009.
  1. mpg's r us
    mpg's r us New Member
    MA
    Just turned 20,000 on my 2010 Prius. Was bought new Sept. 14 2009. I drive 95% highway in New England and have always logged an average of 49.3.
    My trip last week was 880 miles in one day. With a 20 mph head wind on the way to Buffalo, and a 15 mph tail wind home with the cruise set at 73 mph, I still averaged 49 mpg! Cheers!
  2. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    Just kept adding it up in my mileage spreadsheet. I sit in my car while my daughter is at dance class and do work on my laptop.
  3. lunabelgium
    lunabelgium Member
    269
    Belgium (Liège)
  4. Rae
    Rae New Member
    MA
    According to the Prius IV monitoring system, the best we have done on a trip odometer is 57.7 MPG. Currently we have 6089 miles on the 2010 model.
  5. austingreen
    austingreen Senior Member
    13,714
    4,232
    Austin, TX, USA
    duplicate deleted
  6. austingreen
    13,714
    4,232
    Austin, TX, USA
    I'm getting a slightly disappointing 42-43 mpg over 3000 miles. That's actually, computer reads 2.7mpg high.
    Milage is good on the highway and longer trips. I have many short hilly trips that bring the average down. If there are sugestions on how to improve mpg I'll try them.
  7. vday
    vday Member
    312
    Israel
    Thats a heck of a lot of mileage
  8. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    1) Up psi to max shown on sidewall, 2 psi less in the rear, unless loaded.
    2) Combine short trips, going to the furthest one first and working back (minimize cold engine time).
    3) Conserve momentum by watching ahead and planning not to use the brakes where avoidable (accelerate normally, but to a lesser top speed based on looking at impending stop ahead)
    4) Don't coast (foot off gas), but glide using the HSI to direct your throttle so regen is avoided.
    5) On hills, if you are in traffic, pulse up and glide down so your speed is within a narrow range. If all alone on the road, try pulsing down and gliding up with battery assist as needed (ok, granted, your hills are bigger than mine, but try it). Speed range is huge, but you are all alone so who cares.
    6) Read Hobbit's The Tao of HSI here: HSI
    7) Read Hows & Whys at cleanmpg.com, along with their Prius II article and see their update for Prius III.
    Good luck.
  9. TonyWilkey
    TonyWilkey Member
    99
    25
    Kansas
    5th Tank 38.5mpg(calculated) indicated was 40.7mpg moderate cold.
  10. bobboben
    bobboben New Member
    26
    Atlanta
    first long trip. atlanta to dauphin island, al. 800 miles in loaded,,and i do mean loaded 10 prius. avs 59 mph, cruise set to 70 on interstates. temp range 46-64. mpg 49.9
  11. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    it was a gorgeous day Saturday, so went to one of those brushless car washes and without thinking, went thru it without removing my grill blockers. so i have exactly one piece on the top and one on the bottom left. (was 100% bottom 75% top). my tank is currently 56.2 mpg (real mileage around 50-51) i am tempted to leave the block out just to see the difference.
    went to work today, and normally my RT figures run between 51-55 mpg. today was 48.3
    well, looks like grill blocking will be back in REAL soon!!
  12. Tideland Prius
    16,681
    It's been above 0°C all week since the Olympics ended. 4.2L/100km showing on the MFD... so it's probably like 4.5L/100km actual. Halfway through the tank, 467km in. Grille is 85% blocked at the bottom (I lost one small piece and haven't gone around to replacing it since it's been warm.)
  13. dbz
    dbz New Member
    46
    Sunny NorCal
    Wow, some great mileage, I only averages 45.9, :-(
  14. aford3
    aford3 Al10th
    Barto, PA
    Winter MPG lower. Over 2538 miles during 12/09 through 2/10, it consumed 56 gal.= 45.3 mpg. Last fall's MPG was 52.1 over 4952 miles.
  15. ePrius
    ePrius Member
    162
    76
  16. ajc
    ajc Member
    340
    38
    pa
    49.6 mpg
  17. drsbm3
    drsbm3 Junior Member
    34
    manassas
    I am new Prius owner as of Feb. 15, 2010. Still learning driving techniques. My first fill-up after only 202 miles was just 4.04 gallons (50mpg). Second fill-up after 320miles was 6.4 gal (again 50mpg). Third fill-up was at 221miles, 4.59 gal (48.2) gals. All of these mileages were city commuting Wash DC area and weekend errands in town. Feb and early March cold weather, so I am pleased. Now that it has warmed slightly, the MPG gauge is currently reading 58.1 MPG. I am anxious to fill to see actual mileage. Average speeds per trip are ranging 27 to 28 MPH. So far, I would say shorter trips and colder weather reduce mileage the most. Oh yes, with one big exception, my 19 yr old son--he clearly reduces it more than any other one factor or all combined. Grin
  18. kgall
    kgall Active Member
    984
    152
    Olympic Peninsula, WA
    Central Arkansas.
    Bought 2010 Prius II late November 2009; door indicates assembly was 09/09.
    Through early March 2010:
    Miles: 6036
    Gallons: 138
    MPG: 43.7
    [The computer indicates 46.3 MPG--computer error has been consistently about +2.6 MPG]
    Most driving done on Interstates where 70 is the limit.
    Yeah, I'm a bit disappointed, but not horribly so.
  19. Superdrol
    Superdrol Member
    399
    32
    Bought the prius brand new a few weeks ago. Im getting apporx 45 mpg. Is this considered good ?
  20. Superdrol
    Superdrol Member
    399
    32
    Kgall how do you know the mpg computing errOr?
