2010 MPG Stats - Post Them Here
Discussion in 'Gen 3 Prius Fuel Economy' started by BH1973, May 27, 2009.
  1. goldenyears
    goldenyears Junior Member
    Depo Bay, Oregon
    I'm certainly not an expert at driving a Prius, but my technique is to keep on cruise as much as possible... like 90% of the time, even in the city... which requires keeping back from the car ahead by enough distance in order to absorb the slowing and speeding up of traffic without having to change speed. If I do have to slow down I do so by adjusting the cruise so I don't have to disengage cruise. Then when I want to speed up again, I adjust the cruise in small increments to keep the acceleration in the ECO mode as much as possible. Also, I think coasting up to stop signs and red lights will increase mpg. It's pretty hilly here and speed limits change frequently so another technique I use is to wait for declines to accelerate and inclines to slow down when the changing speed limits match the terrain.
    We retired to a rural area where the situation allows for the sort of technique I've described, and I remember quite well that when I was commuting to/from work in "the big city" that if I allowed any room between me and the car ahead of me, someone would cut in front and I would have to hit the brakes, then speed up again when the distance increased. I think that situation cuts the mpg.
    But maybe my technique is not the best and I could increase my mpg even more by doing something different. Safe driving is most important, so please don't urge me to draft behind semi-trailer trucks!
  2. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    That doesn't sound right. I just drove up and over the Sierra Nevada mountains and back, with the A/C set to 74deg and at 70-80mph and still got 45mpg in a GenII. :(
    Are you making lots of short trips?
  3. equake
    equake Member
    155
    Los Angeles
    You might want to check your tire pressure but it should not make that much of a diffrence.
    Check with others in the SoCal area (Thats where I am but don't have my Gen3 yet :cool: ).
  4. Lucky2beme
    Lucky2beme 1st Time Hybrid Owner
    85
    Escondido, CA
    Thank you so much for your reply.
    Yes I take almost all short trips in here in town.
    We got better when we did some freeway driving.
    I thought hybrid's got better mileage in town?
  5. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Ok that is the problem then.
    The Prius does do better in town but short trips will kill your mileage.
    Evertime you start the car you have to go through a warm up cycle and the car is not at its most efficient when this happens. In fact it happens with every car and you will not see a 40mpg average in those other cars. The GenIII should be better with this but you will still suffer from short trip syndrome.
    The best way to try and bring your MPG up and save fuel is to combine your trips instead of making five 1-5 mile trips per day try to wittle it down to 2 or less and you should see an increase in mileage and a beter use of your time. :) If you simply canot change your driving paterns then just smile and be happy you are still getting great MPG compared to just abotu any other car used in such a way. You may be a good canidate for a full electric car so keep an eye out for those when they become more affordable.
  6. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    First long trip for me. 300 miles Chicago to Springboro, OH. Two person on board. Going out used cruise control all the way at posted speed limits, AC on, final MPG 52.2. Return no criuse, AC on, student driver at the wheel for half the distance (not very smooth driver yet), final MPG 54.3.
    With my Gen II the same trip going out and back with the same conditions would have been low to mid 40's.
    Wayne
  7. Lucky2beme
    85
    Escondido, CA
    Thank you for your feedback!
    I know that I am not going to be the poster child for MPGs but I want to be better!
    We are planning a long trip so I will check then!
    I sure love my really cool Prius!:)
  8. Lucky2beme
    85
    Escondido, CA
    I agree with you! I use my auto pilot all of the time. I am surprised at hoew many do not:eek:
  9. burnerx
    burnerx New Member
    32
    2010 PRIUS III w/Navi Black.
    I am still on my first tank of gas.. Got the car last friday!! woohoo!
    Total Mileage at the moment is 199 miles.
    I reached 69.4 MPG while going to work... short distance commute.
  10. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    2010 Prius III with Navi
    Please be aware that the mpg guage, at least in my car, is usually off by 2-3 MPG. For instance my guage reading was 55.0 MPG when I filled the tank it came out to 52.8 MPG.
    I have over 5,000 miles on the car and it has been consistently off by 2-3 MPG.
    Alfon
  11. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    Lucky2beme: You need to learn the car to mitigate your short trips and lead foot (when and to the extent you wish). Look for threads on pulse & glide and the stages of operation (warm up). In town, cruise control is easy and fairly decent, but P&G will crush those results when used properly. You have the easiest car in the world to P&G with; all done with nuance on the gas pedal.
    You can also look over at cleanmpg for xcel's article on hypermiling the Prius II (04-09 models), plus his review of the Prius III. There is a wealth of info here as well.
    Short trips will kill fuel economy, especially when the engine has cooled between trips. This is true of any car, but more noticeable with a high mpg car. HSD hybrids are good in town, assist hybrids like Honda IMAs not so much.
    Congrats on your car and good luck to you.
  12. go10
    go10 New Member
    I'm similar to luckytobeme, I suppose. In my IV, display says 43.3 MPG and pretty stable around there for the first 200 or so miles on first tank of gas still. I've had the "ECO" mode on about 90% of time. My commute is about 6 miles/12 minutes one-way.
  13. barbaram
    barbaram Active Member
    912
    70
    Trenton, NJ
    7/1/09 second tank
    350.4 miles
    6.805 gal
    MFD= 56.1
    calculated 51.5
  14. barbaram
    912
    70
    Trenton, NJ
    3rd tank 7/13/09
    396.1 miles
    7.800 gal
    MFD= 55.1
    CALCULATED 50.8
    7/14- 192 miles to Cape May, NJ averaged about 59.
    I'm going on my first long haul soon and will report.
  15. plevan74
    plevan74 New Member
    PA
    2nd tank in new my 2010 Prius III (replacing a 2000 Corolla) : 500 miles (I took a detour so I could hit that milestone before reaching the gas station !) on 9.5 gallons for an average of 52.6mpg (55.5 on the MFD). The Corolla was doing 32mpg on the same daily commute, so I love the gain in fuel economy !
  16. cantgoback
    cantgoback Junior Member
    santa rosa, ca
    Column 1 Column 2 Column 3 Column 4 Column 5 Column 6 Column 7 Column 8 Column 9 Column 10 Column 11
    0 Tank DATE Gas Distance MID MPG Calculated MPG[/B] MID Error Total Miles Total Gas Lifetime MPG calculated
    1 1 9.936 477 48.4 48.0 +0.4 477 9.936 48.0
    2 2 9.535 431 48.2 45.2 +3.0 908 19.471 46.6
    3 3 9.656 454 49.9 47.1 +2.8 1362 29.127 46.8
    4 4 9.813 465 50.0 47.4 +2.6 1827 38.940 46.9
    5 5 10.836 503 47.5 46.5 +1.0 2330 49.776 46.8
    6 6 11.816 478 45.0 40.5 +4.5 2808 61.592 45.6
    7 7 10/28/09 7.230 321 46.9 44.4 +2.8 3129 68.822 45.5
    8 8 11/03/09 10.021 467 49.7 46.6 +3.1 3596 78.843 45.6
    9 9 11/14/09 9.009 408 48.6 45.3 +3.3 4004 87.852 45.6
    10 10 12/02/09 9.683 411 44.5 42.4 +2.1 4415 97.535 45.3
    11 11 12/22/09 10.082 411 44.1 40.8 +3.3 4826 107.617 44.8
    12 12 01/11/10 9.821 386 41.9 39.3 +2.6 5212 117.438 44.4
    13 13 02/03/10 9.974 408 43.6 40.9 +2.7 5620 127.412 44.1
    14 14 02/17/10 9.997 441 47.1 44.1 +3.0 6061 137.409 44.1
    15 15 03/11/10 9.701 378 43.1 39.0 +4.1 6449 147.110 43.8
    16 16 04/01/10 9.563 397 44.3 41.6 +2.7 6846 156.673 43.7
    17 17 04/23/10 9.684 399 43.6 41.2 +2.4 7245 166.357 43.6
    18 18 05/01/10 8.868 392 46.9 44.2 +2.7 7637 175.225 43.6
    19 19 05/08/10 8.125 387 47.9 47.6 +0.3 8024 183.350 43.8
    20 20 05/22/10 9.047 377 46.7 41.7 +5.0 8401 192.397 43.7
    21 21 05/31/10 7.545 334 46.8 44.2 +2.6 8735 199.942 43.7
    22 22 06/14/10 9.687 409 45.4* 42.2 +3.2 9144 209.629 43.6
    23 23 07/02/10 8.775 365 43.8 41.5 +2.3 9509 218.404 43.5
    24 24 07/12/10 9.310 399 45.4 42.9 +2.5 9908 227.714 43.5
    25 25 07/30/10 8.549 403 50.0 47.1 +2.9 10 311 236.263 43.6
    26 26 08/08/10 9.514 --- --- --- --- --- 245.777 ---**
    27 27 08/21/10 8.168 854 49.9 48.3 +1.6 11 165 253.945 43.9
    28 28 08/28/10 9.176 421 52.1 45.8 +6.3 11 586 263.121 44.0
    29 29 09/05/10 9.591 452 49.5 47.2 +2.3 12 038 272.712 44.1
    30 30 09/18/10 9.626 436 --- 45.3 --- 12 474 282.338 44.2**
    31 31 10/09/10 9.403 421 47.5 44.8 +2.7 12 895 291.741 44.2
    32 32 10/16/10 7.889 374 49.2 47.4 +1.8 13 269 299.630 44.3
    33 33 10/26/10 9.404 425 48.2 45.2 +3.0 13 694 309.034 44.3
    34 34 11/03/10 9.495 444 49.7 46.8 +2.9 14 138 318.529 44.4
    35 35 11/13/10 8.098 360 47.6 44.5 +3.1 14 499 326.627 44.4
    36 36 11/24/10 9.850 414 44.8 42.0 +2.8 14 913 336.477 44.3
    37 37 12/10/10 8.280 329 42.8 39.8 +3.0 15 242 344.757 44.2
    38 38 01/05/11 9.808 389 42.9 39.7 +3.2 15 631 354.565 44.1
    39 39 01/19/11 9.444 381 43.4 40.3 +3.1 16 012 364.009 44.0
    40 40 01/28/11 9.802 428 47.0 43.7 +3.3 16 440 373.811 44.0
    41 41 02/08/11 10.166 431 45.6 42.4 +3.2 16 871 383.977 43.9
    42 42 02/23/11 10.320 408 * 39.5 * 17 279 394.297 43.8
    43 43 ??? ??? 389.6 ??? ??? ??? 17 669 ??? ???
    44 44 03/17/11 10.020 400 42.6 39.9 +2.7 18 069 *** ***
    * Calculated due to carry over from previous trip mileage (forgot to reset).
    ** Wife gassed up, didn't write down MPG and/or trip miles, stats combined with following fill.
    *** Can't calculate total gas/mpg due to missing prior data.
    2 people like this.
  17. fred garvin
    fred garvin New Member
    376
    56
    northern virginia
    second tank
    497 miles (one pip) 9.17 gallons 54.2. mfd said 56.7
    overall 950 miles mfd says 54.8, so probably 53. IV solar 80% hiway but very heavy traffic
  18. ualdriver
    ualdriver Member
    358
    65
    Midwest US
    For all of you that used to own the Gen II Prius, what percentage increase in mileage are you seeing over your mileage from the Gen II? I assume most of you are doing the same type/style of driving with the new car as the old, so I think many of us would be interested in seeing what kind of improvement you're seeing over the Gen II as well as the raw mileage as that doen't necessarily tell the whole story I think.
  19. fred garvin
    376
    56
    northern virginia
    what mileage do yuo get in you UAL ride?
    i think there is a specific thread comparing gen 2 to gen 3 mileage
  20. Fly Boy 5
    Fly Boy 5 Junior Member
    Ohioo
    47.5 mpg measured fuel for mostly hwy driving. Seems to be less in town but still haven't used up a tank.
