2010 - Noise from engine, anyone knows what's causing it?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by neodoru, Sep 7, 2021.
  1. neodoru
    neodoru Junior Member
    Toronto
    Technology
    I've recorded a video of the noise. If anyone has any idea it would be greatly appreciated.
    Turn the volume up a bit.
    52,863
    sounds like a blown head gasket. are you losing any coolant?
  3. ChapmanF
    19,033
    I'm sure not hearing anything that says "head gasket" to me. I'm noticing an odd higher-pitched sound almost like a jingle.
    With recordings like this, it's possible for us to hear very different things, if I'm listening on a tinny little phone and bisco is listening on some audiophile system with a subwoofer.
    We've had some threads that involved loading a sound recording into something like Audacity and emphasizing the particular sound of interest, or even getting a screenshot of the waveform and highlighting the bits that go with the sound.
    Have you tried with a simple mechanic's stethoscope to narrow down the area where the sound originates?
  4. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Whatever it is, it sounds like metal on metal scraping sound. Yikes.
    Cooling fan bearing(s)? Were the fans running when you recorded this clip?
    #4 xliderider, Sep 7, 2021
  5. neodoru
    Toronto
    Technology
    Thanks guys. Went to a mechanic and turned out to be a Rear Catalytic Converter Exhaust Pipe Heat Shield Cover that broke. The noise stopped as soon as it was removed. (I guess I'll replace it at some point)
