2010 observations from the tech's standpoint
Discussion in 'Gen 3 Prius Main Forum' started by galaxee, Jan 14, 2009.
  1. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    are they also acknowledging lack of power and bad mpg of 2nd gen Prius, by improving those two? Or? :cheer2:
  2. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    So, my still unanswered question: If there's no power, how do you unlock the hatch to get to the battery?
  3. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    I wouldn't put it that way.
    However, in talking with the chief engineer, he explained that the 1.8L engine can run at lower RPMs at higher speeds, thus reducing fuel usage, and also having the additional horsepower for when you need it.
    The entire engine/power train is 90% redesigned. It's lighter, tighter, and beltless (eliminates power loss). Also, smaller is not necessarily more efficient, if smaller has to work harder. So by going with the slightly larger engine, it is reducing the load. As one part of a three part power train, the engine is only part of the story. The rest is the way the engine works with MG1 and MG2, which has also been redesigned for further efficiency, reduction of emissions, and better MPG.
    They have kept the Atkinson cycle, as it is the most efficient ICE they have. Until we get PHEV, this looks like a good step forward.
  4. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    We'll hear a lot of improvements be spun as fixes. That just comes with the territory. Fortunately, it's becoming harder and most won't be as extreme as in the past.
  5. john1701a
    12,840
    5,312
    58
    There's probably an emergency release inside for the 2010, just like there is in the Iconic model.
  6. Tideland Prius
    16,642
    Under the rear bar (with the Toyota emblem). Basically, the same place as before but the unlock button isn't as wide and like Rick said, shifted to the left a bit
    That small button to the right is the lock button. Yes those of us with Gen 2s will need some relearning.
    How long is the delay on the Avensis? I swiped it and it took a while to lock.
    Probably the same as before - climbing into the cargo area and finding the emergency release.
  7. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    I want to add a few:
    - Weight distribution is 60F:40R.
    - EGR and EHR (replacing thermo bottle system) add 1 to 2 Kg.
    - The cost of the hybrid system is reduced by 20%. This cost saving is used to make a better car overall. Hint: The base price may be the same as the Iconic model.
