2010 oil filter removal help
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by osiris12, Oct 13, 2013.
  1. osiris12
    osiris12 Owner of 3, yes three priuses
    119
    Upstate NY
    Ok, I'm getting very annoyed. I have the special oil filter wrench and it fits nicely.
    But for the life of me, I cannot get the cartridge filter to budge! Is there a clip or something holding it back?????
    I have a long wrench and I do have leverage, but it won't move. The dealer had done my changes for a while and now it's my turn. I've done oil changes for 25+ years with out issue, until I encountered my 2010 Prius.
    Any help would be greatly appreciated since I have it draining right now. I hate to fill it up with new oil and leave the filter.
  2. Buzzhead
    Buzzhead Non-Interference w/ devel of pre-Warp civs
    151
    59
    Chelmsford, MA
    Yes, there's clip, at about 7 o'clock. But it's probably the o-ring sticking. I've had to use a two-foot breaker bar to lossen the cap after the dealer has put it on. You'll likely have to use a small prybar (slotted screwdriver) to pull the wrench off the cap when you've got it removed.
  3. TsKarma
    TsKarma Junior Member
    82
  4. osiris12
    119
    Upstate NY
    Thanks buzzhead and tskarma for the help. I did finally got it off. And I thing find that useless clip. They the designers actually think that the filter would fall off?
    Anyway, I know next time what to do. It as the o-ring that stuck. But then I noticed the clip that stopped it from continuing. But was able to push it back.... Finally.
    Thanks guys.
  5. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I am thinking why these housings stick is because the dealers are not lubricating the o-ring (with oil) prior to installation. I haven't heard any DYI'ers having problems after they do the service. Just a thought.
  6. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    And yet another job I'd probably mangle that's best left to someone who knows what they're doing :censored:
  7. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Good point, I had not thought about that.
  8. RRxing
    RRxing Senior Member
    2,563
    1,842
    NEPA
    Just changed my oil this afternoon. Yes, always oil the o-ring.
  9. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I do too... because the instructions say to. Of course that is optional at the dealer. ;)
  10. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    If it goes on dry, I could see the ring dry out and adhear to wall with the high temps.
  11. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Even after lubricating the O-ring it still gets very tight when the O-ring meets the housing. I can imagine how tight it is without lubrication.
    spiderman likes this.
