2010 oozing grease from CV boot
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by LazuliNyx, Jun 21, 2025.
  1. LazuliNyx
    LazuliNyx Member
    63
    34
    Georgia, USA
    My 2010 is oozing grease from the passenger side outer CV joint boot. It has 185k miles, there are no tears on the boot, and I have not heard any clicks from the axles. Should I just get a boot and replace it? If so is there a guide for this procedure y’all would recommend? While I’m in there, what are other parts I should replace that will likely fail during the remaining life of the axle? Thanks!
  2. Tombukt2
    Tombukt2 Senior Member
    13,799
    2,502
    Durham NC
    Run it till it turns rotor blue from heat he he . Or close. Do nothing you have years to go the engine will blow before that drive axle causes you any problems unless you live in extreme horrid road conditions like outback
  3. LazuliNyx
    LazuliNyx Member
    63
    34
    Georgia, USA
    With the head gasket issue you’re right, I had to replace mine early this year.
    52,763
    where is it oozing from?
  5. Brian1954
    Brian1954 Senior Member
    2,653
    1,059
    South Central PA, USA
    Read post #1. It is very clearly stated.
  6. ASRDogman
    ASRDogman Senior Member
    8,036
    4,073
    There is likely a tear in the boot. It could be a pin hole, it will leak a lot.
    Or is it leaking at the boot ends? There IS a difference.
    There is a prodecure, Lot's of work. But you clamp the axel in a vice, cut off the clamps.
    Slide the boot away from the outer joint. Then smack the outer joint with a hammer to pop
    it off. There is a "c" clip that snaps the joint on the axel and holds it in place.
    The slide the torn boot off, and the new one on. Put the clamp on first, then the boot, then slide
    the larger clamp over the boot. Align the axel, and smack the axel end(install the axel nut first)
    with the hammer until you hear it POP in place. Install new grease and slide the boot over the joint
    and secure the clamps over the boot.
  7. LazuliNyx
    LazuliNyx Member
    63
    34
    Georgia, USA
    Hi so it looks like it’s coming from around the clamp. Perhaps a pinhole in the boot. I’m wondering if it got disturbed when the crown bolt got stuck on the ball joint I replaced a couple months ago.
    In addition to replacing the boots, what are your thoughts on a reman one? Any vendors who do the OEM shafts only?
  8. ASRDogman
    8,036
    4,073
    Aftermarket ones are not as good. No reason to replace the whole axel when you only need the boot.
  9. Mendel Leisk
    42,251
    The Car Care Nut’s take, albeit a full rebuild, not just boot replacement:
    he advocates rebuild over replacement if possible. Would dealerships take this on, or no?
    a possible business model: a shop selling rebuilt axles, taking yours as a core.
  10. Tombukt2
    13,799
    2,502
    Durham NC
    Clean off the boot with some Stoddard solution or goof off or it's active ingredient once clean you locate pin hole . Put a fresh dab of goop on that spot let it sit 30 min . Check it out now . Clean the mess off the rest
    independent likes this.
  11. LazuliNyx
    LazuliNyx Member
    63
    34
    Georgia, USA
    Thank you! I think I can take this job on. Definitely much easier than my head gasket was. I’m curious about the spider, I’m wondering why can’t it be removed with a 3 jaw puller, which most parts stores will lend. I also checked and there’s clones of the toyota clamp crimper on amazon, I'm wondering if they'll work better than the crimp pliers.
    I'm having difficulty finding the boot kit, none of the dealer sites are matching up the part, so I'm going to have to call the dealers to look it up, for some reason their in store system does a better job than their online. I'm also thinking while in there, I should replace both wheel bearings and perhaps the transmission seals? Does that make sense, since it's a 185k car and all that would be aged.
    I also saw some toyota dealers sell remanufactured axles, but the same problem, they can't find a match for my prius. Would those be a good option as well? They were much cheaper than the new OEM which are like 4 or 5 times more.
    Thank you!
  12. Tombukt2
    13,799
    2,502
    Durham NC
    I have remanufactured axles on several of my Prius no problems at all I mean your axles have 200,000 miles on them I'm guessing . So buying two remanufactured or one remanufactured axle should be a no-brainer I don't everreplace boots n joints ever .I generally buy axles reman locally at driveshaft place . They make and balance my driveshafts for rwd
  13. LazuliNyx
    LazuliNyx Member
    63
    34
    Georgia, USA
    Ok so I checked online and called the dealership. There’s only a boot kit for the driver’s side listed and inner passenger side solo boot. There is no outboard passenger side boot listed which is the one that’s leaking. Does anybody know if the driver’s side boots are the same as the passenger side? I suspect they have the same joints and boots just longer drive shaft on the passenger side. Thanks!
  14. Tombukt2
    13,799
    2,502
    Durham NC
    They should be same . If it's only a pinhole you should really try a dab of goop on the clean rubber after you clean it with carb spray just apply a little bubble and let dry should be good for a long time
  15. LazuliNyx
    LazuliNyx Member
    63
    34
    Georgia, USA
    Thank you. I’ve thought about that, my concern is how much lubrication has it lost so far? It’s a pinhole and hard to tell how much quantity it’s lost, but it’s not a tiny amount either.
    Also I’m thinking it might be a good time to go ahead and replace the wheel bearings for smoothest (as in least friction and loss of mileage) ride.
  16. Tombukt2
    13,799
    2,502
    Durham NC
    The wheel bearings I do about as fast as I get these cars because they're Almost always due at the mileage I'm picking the cars up. So far in the 10 to 30 vehicles I've picked up and worked on I've never seen a split or torn boot yet on a Prius I see plenty on Honda's etc but not my Prius.
  17. Tombukt2
    13,799
    2,502
    Durham NC
    Until I get clicking and noise I leave him alone personally. Once noisey it's time . I may not be in car at that time many this way so far
  18. ASRDogman
    8,036
    4,073
    They are the same, that's why only one is listed.
  19. Mendel Leisk
    42,251
    I've been remiss, something from Repair Manual:
