2010 Owners With The HIGHEST Mileage (total miles driven)
Discussion in 'Gen 3 Prius Main Forum' started by NoMoShocks, Aug 2, 2011.
  1. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    Toyota says never. But you need to check it i want to say every 30k but i'm not sure it's in the manual. People on here say every 30k or 50k or 20k it depends who you talk to.
  2. bledpurple
    bledpurple New Member
    calif
    CHANGE the transaxle fluid its not hard but did mine to late to save the tranny.
    It is definitely not a sealed lifetime transaxle should do every 60,000 I would say now that mine is dead
  3. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    On my Gen3 I have changed transaxle fluid twice, 20K and again at 50K. Used oil analysis from both are posted here: http://priuschat.com/forums/gen-iii...ng/72896-diy-transmission-fluid-change-7.html
    First sample at 20K had a lot of silicone, probably left over from the casting process. The second contained a lot of aluminum, I don't know where that is coming from. If I find out I will let everyone know.
    From what I see in my samples and others that have had transaxle UOAs done I will continue to change at 30K intervals. Although I may change a little sooner next time because of the aluminum.
    My DIY procedure with pictures by Z2R JDM is post #55 of the above thread. Anyone who can change their own engine oil should be able to do this also. A word of caution, be sure to use Toyota ATF-WS fluid because we don't know the electrical characteristics of other fluids.
    Note: Unfortunately "lifetime fluid" usually means the lifetime of the warranty not the lifetime of the car.
  4. El Dobro
    El Dobro A Member
    7,106
    3,282
    Isn't the trans case the only thing that's aluminum?
  5. tumbleweed
    4,067
    692
    Eastern Oregon
    I am not sure, if so it probably means I contaminated the sample with the drain or fill plug or their washers. But there may be some aluminum components in MG1 and MG2 or the planet gear carrier, etc. I will probably send in another sample next summer. I may try to get a sample out of the fill plug hole, I think I can suck out some fluid out with my syphon pump, or even a turkey baster, so I won't have to change it again so soon.
  6. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    At what mileage did your trans die? I saw your earlier post where you have 190,000 miles so far.
    If it were me, I would change at 30, 90, 150, ... Most virgin fluid I have seen is the color of clotted blood, redish-black, after 60,000 miles. Unfortunately, I do not buy new cars, so the first change is when I take possession and then every 60,000 thereafter.
    If you do not change your fluid, set your expectation to 200,000 miles.
  7. lolder
    lolder New Member
    There should be nothing aluminum to wear in the transmission/MGs.
  8. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    I will link this post in another thread: "100k miles"...
    http://priuschat.com/forums/gen-iii-2010-prius-main-forum/86189-3gen-100-000-mile-club.html
    Please drop by and give us some information/ownership experience...
    Also seems you are getting a prize for being the 1st 100k miler on a 3Gen in PC. Congratulations!
    When coming to Portugal, please send me a PM for the coffee.
  9. silverdan53
    silverdan53 New Member
    Jackson, MS
    brand new to the forum. Bought my Gen 3 2011 Prius on April 19, 2011. Will hit 58000 miles within a week. Just extremely satisfied with it so far. Most enjoyable car I've ever owned, ... and I've owned a number over my 58 years. Not one issue yet, other than those caused by me, or others, .. ie, rock to the windshield, tire treads on the highway, etc. Original tires still not looking too bad, not much brake wear yet. Plan on putting over 100,000 a year, and hoping it can make it for four or five years. Lots of miles, but I'm an easy driver, with a gentle braking and acceleration foot. Staying on top of scheduled services.
  10. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    That is a bunch of miles SilverDan. What type of MPG's are you seeing? Is your car used for work or are you driving laps around the US for fun?
  11. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    5 months as of yesterday and I just crossed 15,000.
  12. orenji
    orenji Senior Member
    5,887
    3,490
    2010 with 63,000 miles, only oil changes, rear brakes and tranny fluid changed at 61,000 miles......
  13. RRxing
    RRxing Senior Member
    2,564
    1,842
    NEPA
    100,100 as of last week. Averaging about 14k/year.
    orenji likes this.
  14. Tanderson82
    Tanderson82 New Member
    Covington, LA
    Any updates on the cars? Mine is at 165,000.
  15. Analogkid1958
    Analogkid1958 Member
    123
    61
    Yorktown, IN
    2024 Prius
    My 2010 Three lunched its traction battery...at 305,538. It's been sold to a mechanic to rebuild and replaced with a 2017 Three. Amazing vehicle!
  16. Groger
    Groger Member
    70
    25
    52000 miles, Wiper motor, oil change, that's it. (bought 8 months ago, who knows what they did to cause the wiper motor to die)
  17. Mendel Leisk
    42,369
    Geesh, it took it's sweet time dying. I guess it's not exclusively miles that kill them, time's a factor too.
    Our's is barely broken in: 67K km's, roughly 42K miles. Still on original air filters, wiper blades, tires and so on.
    Analogkid1958 likes this.
  18. Jomarayprius
    Jomarayprius 2010 Prius, 2014 Prius
    Ontario
    Premium w/ Solar Cells
    239,300 kilometres as of August 26, 2018
    Raytheeagle and Mendel Leisk like this.
  19. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    We have 185,555 miles on our 2010 as of last night:).
    While not as high as some on this thread, still a good amount and trouble free(y).
  20. ASRDogman
    ASRDogman Senior Member
    8,069
    4,092
    I turned 144,000 today. Still running good!
    Mendel Leisk and Raytheeagle like this.
