2010 P0302 Cyl 2 Misfire & White Smoke
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by CharlesPrius, Jun 18, 2018.
  1. JC91006
    16,769
    8,567
    I'm hoping to join a class action suit against Toyota for reducing the resale value of my Turd gen car. There should be at least a TSB issued for this problem.....but wait, then they'll open up the law suit flood gates
    SFO and The Critic like this.
  2. CharlesPrius
    CharlesPrius Member
    154
    60
    Thanks I will mention this to mechanic when I get back
  3. CharlesPrius
    CharlesPrius Member
    154
    60
    Just dropped off the coche. $1550 estimate includes new head gasket, machining the head, new water pump, & cleaning the EGR circuit. Probably needs new valve cover gasket but that's just the cost of the part, $20-$40. Praying there's not more wrong with it; they estimate to be done at the end of today. Will update.
  4. CharlesPrius
    CharlesPrius Member
    154
    60
    WRAPUPDATE: Had the job done about a week ago. Total came to about $1550, took them about 2 days. They said it didn't need a valve job. So far so good after about 250 miles. No CEL and no rough starts, not losing coolant anymore. Hopefully this fix will last another 170k.
    Raytheeagle likes this.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    If by that you mean you think it will go another 170K miles without another (different) major problem.......I think you are dreaming.
    But it's possible I guess.
  6. ASRDogman
    ASRDogman Senior Member
    7,607
    3,915
    Probably, as long as you keep the egr cooler and related parts cleaned out.
    mjoo likes this.
  7. CharlesPrius
    CharlesPrius Member
    154
    60
    yeah they cleaned the EGR circuit
  8. CharlesPrius
    CharlesPrius Member
    154
    60
    of course not, i just mean the head. i fully expect to need shocks in 1 week since i live in los angeles
  9. CharlesPrius
    CharlesPrius Member
    154
    60
  10. ASRDogman
    7,607
    3,915
    I meant as far as engine wise... shocks, bearings, etc., if normal wear and tear.
