2010 passenger airbag light
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jayw13702, Oct 5, 2015.
  1. Jayw13702
    Jayw13702 Active Member
    142
    170
    Plymouth UK
    im in the process of buying a 2010 gen3 and I have a query.
    I haven't seen the car yet but have see pictures, in all the pictures the ignition is on and so is the passenger airbag light (in yellow)
    I haven't asked if the airbag is switched off yet but if the airbag is switched on should that light be on?
    I don't want to travel 200 miles to look at a car that possibly has faults, the money that they are asking is such it should be flawless.
    This is a UK spec T4 car btw
    Thanks for your help
  2. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Situation normal. The light is on to indicate the airbag is functional.
  3. macman408
    macman408 Electron Guidance Counselor
    1,179
    368
    I think the "passenger" light may always be on when the car is on, but it won't say either "Air bag on" or "Air bag off" unless someone is sitting in the seat. Once someone sits in the seat, it'll decide if they're an adult or a child, and then turn the air bag on for adults, and indicate the status through one of the two lights.
    The only warning light you need to worry about is the SRS warning light on the dash; if that light stays on (beyond when the car first starts up and runs the self-test), then there's a problem. In that case, the Air Bag OFF light will be illuminated.
  4. Manhal K Alrashdan
    Manhal K Alrashdan Junior Member
    81
    16
    jordan
    When there is a passenger in the front seat the airbag should always light on , that means it's armed or functioning .
  5. Mendel Leisk
    42,347
    Either with or without someone in the passenger seat, there'll be one light or the other on. It is kinda jarring, gets you thinking something's wrong, but that's what it is. For example, if you have a lightweight kid in that seat, the lights will warn that the air bag's off.
