2010 Plastidipped Emblems
Discussion in 'Gen 3 Prius Accessories and Modifications' started by detroit11, Mar 16, 2013.
  1. detroit11
    detroit11 Junior Member
    Photo Mar 16, 1 01 46 PM.jpg Photo Mar 16, 1 01 54 PM.jpg Photo Mar 16, 1 16 49 PM.jpg Photo Mar 16, 1 16 57 PM.jpg Photo Mar 16, 1 20 26 PM.jpg Photo Mar 16, 1 23 50 PM.jpg Photo Mar 16, 1 24 01 PM.jpg Dropbox - Photos
    Never used it before. Worked very well and was easy.
    The wheel covers are in process.
    I have cut out the blue strips on the hybrid. I did the front emblem as well but pulled up some of the dip on the emblem so I will have to redo that. Photo Mar 16, 1 24 01 PM.jpg
    ockevin and SoCal65SS like this.
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Well done.
  3. SoCal65SS
    SoCal65SS Member
    72
    44
    Southern California
    Looks good!
  4. detroit11
    I just noticed the pictures are upside down. They were not in drop box. I dont know how to correct that oops.
  5. Ursoboostd
    Ursoboostd New Member
    24
    Florence, Ky
    Did you take off all the emblems for paint?
  6. detroit11
    no I masked of everything and used plastidip. it worked great and was easy
  7. 2clicker
    2clicker Member
    114
    28
    St. Louis
    how easily are the emblems removed? is it adhesive or some sort of rivet or fastener holding them on?
    cant wait to see the wheel covers.
    *EDIT*
    so you left the emblems on the prius?
  8. detroit11
    yes I left the emblems on. I did not remove them. Although I undertand everything other than the T's are secured with an adhesive. any overspray can easily be wiped away with a microfiber towel. but I suggest masking it off so you dont have to mess with it.
    its been to cold to finish the wheels. they are prob good have 6 coats but I want to do some more.
    2clicker likes this.
  9. 2clicker
    2clicker Member
    114
    28
    St. Louis
    how well will plastidip hold on the wheels?
    this stuff seems pretty easy to work with. if i sprayed it on my wheels i wouldnt want it peeling off until i was ready to peel it off.
  10. detroit11
    it pretty much wont peel off until you want it to. especially if you put it on right. make sure you do enough coats.
  11. jmrmotorhead
    jmrmotorhead Junior Member
    85
    44
    New Hampshire
    Emblems pop right off. Use a credit card slide under the right side of the rear chrome piece, and push inward. It will release the clip and you can pop it out. For the front, the upper radiator shroud must be removed, and you reach your had into the TINY space and unclip the chrome part, and push out.
    Matt
  12. nivlac915
    nivlac915 Member
    77
    56
    up in the hills of covina, west side
    nice job detroit11..!!
  13. techno-Zen
    techno-Zen Junior Member
    Mesa, Arizona
  14. Accordlayingkit
    Accordlayingkit Senior Member
    1,618
    1,748
    377
    Colonial Heights, Va
    so you jus used like a lot of painters tape around the emblems? what about the plasti dip getting inside the letters which is the background of the car
  15. StarCaller
    StarCaller Senior Member
    1,282
    732
    Cedar Crest, NM, USA
    it comes off the background & adheres to the letters/emblem.
