2010 Prius’s mileage going South
Discussion in 'Gen 3 Prius Fuel Economy' started by Norryboy1a, Feb 2, 2020.
  1. bisco
    51,895
    interesting. i wonder what higher octane accomplishes? i'll have to try a tank, i wonder if it would get me from the 60's into the 70's...
  2. Norryboy1a
    Norryboy1a Junior Member
    Pennsylvania
    I think it could be that the injectors are dirty/clogged. Not sure. But, I am glad this seems to work.
  3. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    While your at it, throw in some 0w-16 engine oil.
  4. Norryboy1a
    Pennsylvania
    If I can find it, I’ll try some
  5. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
  6. ASRDogman
    ASRDogman Senior Member
    7,570
    3,904
    A fluke. Either the previous fuel you had gotten was bad, and putting in good fuel diluted the bad,
    and now it's more burnable.
    Grit likes this.
  7. Eric34
    Eric34 New Member
    Sacramento
    Agreed with al you said. I have done exactly the some way you have done it. It took exactly same amount time. 25 min job.
    ASRDogman likes this.
  8. ASRDogman
    7,570
    3,904
    If someone has not done a lot of work on cars, it will take longer. And that's not a problem.
    As long as it's done right, and goes back together okay.
  9. Mendel Leisk
    41,400
    That's me, lol.
    #29 Mendel Leisk, May 6, 2020
  10. Norryboy1a
    Pennsylvania
  11. Mendel Leisk
    41,400
    Has anyone mentioned injector cleaner (gas tank additive). Look for one with recommendations and PEA.
    I got a concentrated bottle at Canadian tire a couple of years back, put in recommended amount when fuelling up, maybe every 6 months.
  12. Norryboy1a
    Pennsylvania
    I tried a bottle of Lucas high mileage fuel additive. Not much of a change.
  13. Norryboy1a
    Pennsylvania
    Maybe, I should pull the negative terminal off the 12 volt just to reset the ecu’s. I have a feeling that maybe that can help somewhat. Just for giggles.
  14. Norryboy1a
    Pennsylvania
    I had often wondered if maybe there is an increased drag in the engine from an a/c compressor needing more refrigerant oil (like pag or whatever they use now).
  15. Mendel Leisk
    41,400
    We're all on the same page, that AC use (regardless of oil quanitity) impacts mpg?
  16. ASRDogman
    7,570
    3,904
    The compressor runs off the hybrid battery, not the engine. There would be no drag.
  17. Norryboy1a
    Pennsylvania
    That’s interesting. Where is the compressor?
  18. Norryboy1a
    Pennsylvania
    Maybe it’s drawing too much load.
  19. Norryboy1a
    Pennsylvania
    Did a little reading. Decided only to let the dealer check the a/c. Found out that ND11 is the only oil that should be used. And due to the possibility of contamination from other a/c Service shop’s machines using different oils, the dealer, I think should be the one to check it. The compressor still may be pulling too many amps. But then I guess the fuse would blow. I’ll keep at it.
  20. Mendel Leisk
    41,400
    If you're saying using AC in a Prius would have no impact on mpg, I'd argue that. It doesn't matter if it's Peter or Paul supplying the electrons for the compressor, it will impose a mpg penalty.
    Still mpg at initial post was high 30's for two tanks, but is now back in the 40's? With higher octane gas?
    I'd still think with 170k miles just clean the intake and EGR asap.
