2010 Prius 1
Discussion in 'Gen 3 Prius Technical Discussion' started by David22, Nov 17, 2021.
  1. David22
    David22 New Member
    I
    I have a 2010 Prius 1 with 200,377 miles on it. Should I / is it recommended to replace the brake actuator and brake booster on the vehicle before any brake problems start to occur? Since the Prius has high mileage. Thanks!
    52,854
    welcome!
    i have never read about anyone doing that. they don't all go bad, so it would be hard to justify, unless you absolutely want to eliminate all possible risk.
  3. nancytheprius
    nancytheprius Active Member
    365
    157
    iowa
    Yeah id vote to hold off as well
  4. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
