2010 prius 12v battery?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kknguyen1168, Mar 3, 2013.
  1. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    hi all
    I will need to replace my toyota 12v battery soon, Optima battery is so expensive, I was thinking Costco Kirland battery, please tell me what you guy think about Costco Kirland battery?
    V/r
    Khoi Nguyen
    Most auto batteries are made by just three manufacturers, Delphi, Exide, and Johnson Controls Industries. Johnson Controls makes Diehard (Sears), Duralast (AutoZone), Interstate, Kirkland (Costco), Motorcraft (Ford), and some EverStarts. – Source Consumer Reports
  2. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    I think in general the batteries sold by Costco are as good as any. I have them in my pickup and my lawn tractor. The problem is they don't make a battery specifically for the Prius and their batteries are not sealed such as the Optima and have no vent tube as the Toyota battery does. This may not be be a problem and there is at least one poster on here that uses them anyway. But when mine goes (any day now I expect) I will most likely just play it safe and pay the $200 for an Optima.
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    So long as it is a externally vented AGM battery, you are safe, reversed terminals and JIS Posts certainly make it easier to install, as well)
  4. Mendel Leisk
    42,242
    Are you considering also the Toyota sanctioned battery, ie: the one you would get if you just walked up to a Toyota parts counter and asked?
    Just curious, since owners seem to stay away in droves from this option. Is it overpriced, underpowered, or? It would be the option that would dimensionally fit.
  5. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    Mendel
    Overpriced, not good reputation.
  6. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
  7. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    CSS28
    compare this to Optima, I will take Optima. The reason I would like to replace within 2 month because the factory battery it happen to die with 2 to 3 years period, my brother had same car and battery die in 2 years but he got over 50k miles, I just want to be safe and do not want to get stuck in freeway.
  8. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    hi all
    By the way, where can I get good price for Optima battery for my 2010 prius.
    V/r
    Khoi nguyen
  9. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  10. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    Jimbo
    is Optima d51r fit for 2010 Prius? it call for
    Optima DS46B24R and it is 198.00
    V/r
    Khoi nguyen
  11. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  12. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
  13. macman408
    macman408 Electron Guidance Counselor
    1,179
    368
    You won't get stuck on the freeway, if that's what you intended to say. Once the car is started, it doesn't need the 12V battery any more. You might get stuck at home, or at your destination, when you've turned off the car, but not while you're in traffic.
    You could always take it to some place that offers free battery tests. At least if they tell you that it's still good, you KNOW it's still good. (And if they tell you to replace it, maybe it's time, or maybe they just want to sell you a battery.)
    xpcman likes this.
  14. szgabor
    szgabor Active Member
    994
    175
    Oceanside NY
    How would tht happen ?? You pull over on the highway and stop the car and turn it off ??
    Even an almost dead battery after driven on the highway for some time will have charge to boot the car ... the problem is overnight or a few days left on the parking lot !!! Not getting stranded on the highway ... in my opinion.
  15. gliderman
    gliderman Active Member
    751
    225
    I still have my original battery and 60k+ miles. No sign of going out. Yet.
  16. szgabor
    994
    175
    Oceanside NY
    Quite possibly true. Since battery life is not depend on milage more like time and how many times if ever it was completely discharged. And some other factors like temp ....
    When the prius used less often or very short trips .. the 12V battery will not really fully recharged ... and low SOC for extended period of time damages it ... simply will hold less and less charge. Even manual says that car needs to be put on Ready (in park ) to recharge the 12V battery
  17. retired4999
    2,652
    627
    Eau Claire, Wi.
    My last prius ,a 2005 with 60,000 miles. I had for seven years and it had orginal battery when I sold it, still just fine no problems ever!
  18. kensiko
    kensiko Member
    260
    58
    Qc, Canada
    2014 Tesla Model S
    I find it really stupid that Toyota didn't put a timer for every light in the car. My Sentra does this, any light that is turned-on will turn off whatever happens after a period of time if the key is removed.
    Anyway, since I got the car a month ago, I just checked the battery voltage, it was 12.4V with door lights turned on. I hope the battery will last for a while, I do leave the car many days without using it (I work from home).
  19. zencar
    zencar Junior Member
    34
    Venice, CA
    My 2010 Prius III (June 2009) with 26k miles went in to "P LOCK MALFUNCTION" mode twice. Once the engine started after 6 hours, the second time needed a jump. I know I need a new battery, but that seems like pretty short life.
  20. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I always claim they last 4 years in any car, they usually beat that, but by 4 years it is time to plan to replace it.
