2010 Prius, 180k - Help! Increasing loud road noise since putting 2 new tires
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Shamrock2012, Jan 19, 2019.
  1. Shamrock2012
    Shamrock2012 New Member
    Massachussetts
    Recently I had a credit for Sears so I took a chance on installing 2 new 3 season continental tires.
    Ever since, I’ve had noticeably louder road noise from the back end where the tires are. At first I just thought it was the new tires but it’s getting louder to the point where people are commenting it sounds like being on a roller coaster or as if something is rubbing on the plastic frame of the car.
    I checked it out and didn’t see anything obvious. Does anyone have any ideas of ways I could check it out before going into the shop?
    I noticed another post with the same issue, interestingly he also went to Sears auto.
    Many advised it may be a wheel bearing. Is it possible/likely they messed something up during the tire change? I didn’t there was much in the way they could mess up mounting 2 new tires.. It does have 180k on it so it certainly could be a normal wear.
    Is there any way to test or see if it’s a wheel bearing or something else? Is it unsafe to drive if it is one that is going? Any advice on how to replace the broken parts in a less expensive way while maintaining quality?
    Thanks for any advice!
  2. Shamrock2012
    Massachussetts
    I put down the windows and drove in a parking lot on a smooth surface and didn’t hear anything. It gets worse at highway speeds above 25mph. I did not notice it getting worse changing lanes or cornering.
    It starts as a faint ‘wub wub wub then develops into an RRrRrRRR that comes from the rear cabin. My Dad thought it sounded like I had snow tires with cleats or something similar. Thanks again for any help
  3. Grit
    Grit Senior Member
    6,102
    4,032
    Wilkes Land
    If the new tires are in the rear, move both to the front. Drive it and if the sound is up front then it's the tires.
    Pluggo likes this.
  4. Ballbearing
    Ballbearing Junior Member
    38
    16
    Huntington Beach, CA
    Ditto... this is what I did with my old Honda Element and the noise was still present. I thought it was my 40% tires, so I got a whole new set of General Grabbers, and the roller coaster sound didn't vanish. Turned out to be two bad wheel bearings in the rear.
  5. FuelMiser
    FuelMiser Senior Member
    1,259
    853
    Monument, CO
    We really need to know the model of the Continental tire. They make very good LRR tires called TrueContact, but others may not be so. It could also be that the tread is directional and they were mounted in the wrong direction. That's why we need the model. Does the sidewall have any markings as to the direction they should be mounted. Maybe an arrow indicating direction of rotation.
    Shamrock2012 and Grit like this.
  6. tankyuong
    tankyuong Senior Member
    1,555
    659
    Central MO
    Raise your car and spin the wheel
  7. Grit
    Grit Senior Member
    6,102
    4,032
    Wilkes Land
    (y)(y)(y)(y)
  8. jack black
    jack black Active Member
    225
    142
    I
    i don't think popular tires made by continental are directional .
  9. Shamrock2012
    Massachussetts
    I was mistaken, the tires are CooperTires CS3 Touring
  10. Shamrock2012
    Massachussetts
    Apologies, the tires are not Continental as I wrote, they are Cooper CS3
  11. Shamrock2012
    Massachussetts
    Thanks guys, the rear passenger wheel bearing was completely shot.
    Mendel Leisk, kc5dlo and Raytheeagle like this.
  12. 04priusnow
    04priusnow Active Member
    345
    200
    just replaced my rear bearings.. same as your right rear was toasted. I replaced both though just in case. my car started sounding like I was in a prop plane and trying to take off on the highway. lol
    PH-1 ?
