2010 Prius 181k miles- what maintenance should I do?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mmadarling, Aug 9, 2020.
  1. mmadarling
    mmadarling Junior Member
    New Hampshire
    2010 Toyota Prius. Purchased in 2017 with 121k miles
    I've had the oil and filter changed regularly. Had the EGR cleaned. Have changed the cabin and engine filters.
    Can you tell me everything I can do to extend the life of my car? It's running well. No issues and I want to keep it that way
    Thank you, in advance
  2. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Egr circuit cleanse, intake manifold cleanse and occ installation.
    mmadarling likes this.
  3. Mendel Leisk
    42,378
    You've done both coolant circuits?
    Transaxle fluid?
    Brakes?
    mmadarling and Grit like this.
  4. orenji
    orenji Senior Member
    5,887
    3,490
    Transmission fluid, both coolants, spark plugs.
  5. mmadarling
    New Hampshire
    The brakes have been replaced. I don't believe the brake fluid has been.
    Do you have any further info? What's an OCC and how do I do these things?
    Thank you
  6. mmadarling
    New Hampshire
    Thank you! That's a great start
  7. orenji
    5,887
    3,490
    OCC - oil catch can. It collects oil before it blows into the EGR, and throttle body. It helps with reducing the amount of oil build up in the EGR and manifold. Most have it installed when doing the EGR cleaning.
  8. Tekken
    Tekken Member
    260
    77
    Los Angeles, California
    replace that Water pump I see no one mention that.
  9. Mendel Leisk
    42,378
  10. mmadarling
    New Hampshire
    I bought an Aisin water pump. They're OEM water pumps with the Toyota symbol grinded off. Got it open box on Amazon for $160. Thanks
    AzusaPrius likes this.
