2010 Prius 187K engine code P0038 and P2237
Discussion in 'Gen 3 Prius Main Forum' started by RC12, Aug 24, 2018.
  1. RC12
    RC12 New Member
    pacifica
    My 2010 Prius III been giving me problems. I am having the engine code P2273 and 0038. The dealer said replace both o2 sensor and it will solve the problem. They tried to charge me for $1000 dollars for replacing both sensors.
    I replaced them on my own, but the codes are still there. Please advise. My car has 187,000 Miles on it.
    amos likes this.
  2. Row Kam
    Row Kam Junior Member
    Hello did you find any solution to your problem ? My Mechanic said changing the engine module relay will possibly solv the problem ?
  3. bmk
    bmk New Member
    MAURITIUS
    hi .i got a prius 2010 when i drive some km there is like air suction in the engine and the gear start to fail and the triangle light on and engine light too and then i continue to drive with engine light on works perfectly, the ob2 scanner say battery fail,is it the e.c.u and inverter,..
    I REACH 143000KM
    52,861
  5. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    This will be hard to fix without logging some data. I would like to see how the short/long term trims, MAF, air fuel sensor and rear o2 sensor behave under a variety of conditions.
    I suspect the issue has something to do with the MAF acting differently than what it is reporting and is causing the car to be over-fueled.
    Raytheeagle likes this.
