2010 Prius 194k miles
Discussion in 'Gen 3 Prius Technical Discussion' started by Terri Salhus, May 27, 2021.
  1. Terri Salhus
    Terri Salhus Junior Member
    I hope someone can help me, even just a little so I don't drive into the repair shop without a clue, and get burned. I just bought this prius, every once in a while when I go to start it, I hear a clunk noise, sounds like it's coming from the front maybe left side, and it doesnt start. I put the brake back on, push the button, nothing again, after a couple times, kicks right overhand runs fine for a few days, then repeats. Until yesterday, it did make that horrid sound again, but never started up. I've put a diagnostic on it, no codes. I tried jumping it, still nothing. All the lights come on on the dash, bright, including the orange triangle with an ! Now I'm thinkin starter? Then I hear it doesnt actually have a starter, does this sound familiar to anyone and if so, what can it be?
  2. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    Check the 12v battery. In the trunk, passenger side. You'll have to pull the carpet and tray out
    to get to it. If it's under 12 volts, it might be bad. Look for a date code.
    How long had the car sat before you got it?
  3. AzusaPrius
    AzusaPrius Senior Member
    2,258
    953
    How long is every once and a while?
    You might want to look at the 12v.
    These cars click, clack and knock for various reasons, they will tell you its the head gasket or HV battery right away.
    First things first have the 12v checked.
    Then replace it if needed, the HV battery starts the engine so if that is weak already and you start the car "every once in a while" then that HV may need attention.
    Make sure you have a fresh oil change and check the dipstick in the morning before starting the car.
    Depending on your DIY skills and pockets
    I would change the air filter and spark plugs to start, then you will hear people on here clean the EGR cooler!!!!!
    You need to drive these cars or else the batteries drain just sitting there.
    http://www.RedBullet.net
    http://www.ProjectLithium.com/?ref=mG0GE
    http://www.Pulstar.com
    http://www.PlugOutPower.com
  4. Mendel Leisk
    42,387
    Yeah. 194k miles, no kidding; it’s overdue. More info:
    Bad Flywheel | PriusChat
    Oh, and: if you ask about this at a dealership they’ll look at you like you’re speaking a foreign language. And/or do a parts replacement frenzy that’ll set you back close to a grand. Everything IS cleanable, but dealerships don’t do that. DIY the cost is trivial, under $100 even if you replace every gasket you encounter.
  5. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    yeah, the egr circuit cleaning is like the 2nd to last big boss of videos games. Then save a few more grand for the final big boss- engine head gasket replacement. But you’ll need to pass level 1 first.
    Raytheeagle and Mendel Leisk like this.
  6. Mendel Leisk
    42,387
    Except, if you defeat that second-to-last boss (EGR and Intake Manifold clean out), early enough, maybe the last boss (head gasket failure), never shows. Again though, 194k is late in the day; 100k is when you should get on it for sure.
    Raytheeagle and Grit like this.
  7. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    how absent-minded of me, forgot the game of wack-o-mole. This car comes with 2 games!!!
  8. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Install an oil catch can early enough and we'll see if we can have the final boss lay in the background too;).
    So far with the catch can install on our 2019 Prime I've caught over 5 ounces for the 20k miles it has been installed:cool:.
    And that's at 67% EV for those miles:cry:.
    I'll see how much the catch can and egr circuit redesign help ward of the final boss:).
    Note on the Gen4 / Prime that the second boss got harder:whistle:.
    But I'm up to the challenge for some data(y).
    Tbkilb01 and Mendel Leisk like this.
