2010 Prius 3 check hybrid system, engine code P0094?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by rockcube69, Jan 22, 2021.
  1. rockcube69
    rockcube69 New Member
    los angels
    i have a 2010 Prius, i just got the head gasket replaced a few months ago, was having a misfire and leaking coolant that was fixed, not the Prius died on the highway, hybrid battery drained two bars, pulled only one engine code P0094 which was for a fuel leak detected, i replaced with a used fuel pump from another crash Prius, after install disconnected battery and pulled orange plug for reset, still showing code P00094 even after clearing and "check hybrid system" please and one with information can help, I'm really in a pickle
  2. rockcube69
    los angels
    my scan reads P0094, but i cant seem to find any information on this code for Prius am i mis reading this code for P0A94? which is an interverter failure?
    51,082
    could be, that would kill it on the highway, might be the transistor recall. what are you reading codes with?
    any movement in the inverter fluid reservoir?
  4. rockcube69
    los angels
    anyone else familiar with a P0094? code bump
