2010 Prius 3 Low MPG
Discussion in 'Newbie Forum' started by Xtian1, Apr 20, 2017.
  1. Xtian1
    Xtian1 New Member
    Orange county
    Bought this 2010 Prius 3 two weeks ago from now and started out getting 38pmg maybe a bit better but I've been in LA lately and been hitting some traffic but my MPG says I'm getting 24.7 mpg now and has been dropping? What's this mean? My horn doesn't work as well!
  2. Xtian1
    Xtian1 New Member
    Orange county
    And my mileage is around 85,000
  3. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    Do you have any history on the car? How many miles have you put on in the 2 weeks of ownership?
    Other than mpg, do you notice anything unusual, like hesitation under throttle, misfire, dash lights, etc?
    What mode are you driving in (eco, power, normal)? Clean title (or salvage)? What tire pressure do you have? What gas are you buying (top tier or whatever is available)? Are you running with the AC on full blast?
    As you can see, there are plenty of possibilities for low mpg:(.
    Keep us posted(y).
    52,886
    congrats and welcome!
    you can't tell anything looking at the dash. after you've put in a few tankfuls and measured at the pump, let us know what you're averaging.
    i doubt the horn is related, you're going to have to do some investigating. start with the fuse.
    a few things you can check in the meantime:
    1) what kind of tires and what pressures?
    2) how old is the 12 volt battery, and what does it measure after being off for a few hours?
    3) is the cooling fan and intake grille clean?
    4) are the air and cabin filters clean?
    5) is the oil level correct?
    6) are the intake, egr, throttle and maf clean?
    7) is the pcv working properly?
    all the best!(y)
    #4 bisco, Apr 20, 2017
  5. Xtian1
    Xtian1 New Member
    Orange county
    Car had no accidents reported w/ 2 owners from Indio, CA w/ clean title. I've put about a few hundred miles since not sure how much exactly. No misfire or dash light problems thank goodness! I've been driving in PowerMode. But when I hit bumps it sounds loud so I might need to fill my tires up I will check that today! I'm using premium gas and been using AC a good amount as well!
    Raytheeagle likes this.
  6. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Another thing worth checking in addition to the above would be a brake system check. If you have a brake dragging that could lead to increased friction and lower mpg.
    Xtian1 likes this.
  7. Xtian1
    Xtian1 New Member
    Orange county
    Alright thank you for the help here's some photos of my mileage trip A & trip B ! And overall MPG I'm getting. Maybe it's going lower because I'm not resetting the mileage meter.
  8. Xtian1
    Xtian1 New Member
    Orange county
    Here's my overall MPG
  9. Xtian1
    Xtian1 New Member
    Orange county
  10. bisco
    52,886
    use regular gas.
    10PriusIV and Mendel Leisk like this.
  11. bisco
    52,886
    i don't see any mpg in this screen?
    10PriusIV likes this.
  12. Prodigyplace
    12,720
    11,852
    Central Virginia
    Check post 7
  13. bisco
    52,886
    yes, i see it on those, thank you.
  14. Xtian1
    Xtian1 New Member
    Orange county
    You think it's because I need to reset the trip A and B ?
  15. Mendel Leisk
    42,368
    Yeah "premium" gas might even be detrimental to mpg, it is basically higher octane, and it's main function is to better resist ignition. At best it's doing nothing.
    It's use is only warranted in high compression engines. It's a waste of money too.
    Bisco's list involves some fairly in-depth checks, I would start with the low-hanging fruit: tire pressures for example. What make/model of tire are on there btw? They will have minor impact, but you have to start somwhere.
    Also, how long are your trips typically, and what speeds?
  16. fuzzy1
    10,722
    Absolutely! How many of those 7000 miles are yours? Probably very few, so your personal MPG is swamped by previous use. Clear them out now.
    After resetting those trip meters, let us know what numbers are displayed after a few hundred more miles. If they are still low, then we'll have you answer this questionnaire to give us more clues:
    Fuel economy complaints/queries? Please copy, paste & answer these questions, esp. if you're new | PriusChat
  17. Xtian1
    Xtian1 New Member
    Orange county
    Thank you for all the info!! I'll fill it up with regular next time! And went to Americans tires today for a free pressure check and they said it's good. My trips a day vary from 20 to 50 miles per day and I try to take it easy on the freeways I don't go past 70mph and streets I'm staying under 40mph
  18. Xtian1
    Xtian1 New Member
    Orange county
    Ok I just found out how to rest my mileage ! Thank you for the help! I reall do appreciate it!! I'm going to take a little drive right now and watch it my MPG now that it's reset!
  19. fuzzy1
    10,722
    Tire air pressure gauges are cheap, it is very worthwhile having one of your own in the car so that you can monitor it yourself on a convenient schedule.
    Also, 'good' is not the answer we are looking for, we want to see actual PSI numbers. Specifically, for your model year, the front tires should be at least 35 psi, the rears 33. Somewhat higher is also fine, if a slightly harsher ride doesn't bother you.
    If the tire shop guys are thinking generically for other car models, they might say 'good' for 32 or even 30 psi, which is too low for your car. Plus, these numbers should be measured when the tires are morning cold. Driving them more than a few miles warms them up a bit, complicating the reference back to the requirements printed on the door frame label.
    Raytheeagle, Xtian1 and Mendel Leisk like this.
  20. Xtian1
    Xtian1 New Member
    Orange county
    Ok thank you for that & I found the psi # ! I'm going to check them again
    fuzzy1 and Mendel Leisk like this.
