2010 Prius 5 w/ advanced tech
Discussion in 'Gen 3 Prius Main Forum' started by Devan R, Sep 18, 2021.
  1. Devan R
    Devan R New Member
    Oregon
    Hey everyone. I've been hunting down myself a Prius as my first vehicle. Managed to survive college without forking out dough for a car but the time has come and I want to make sure I'm getting myself a car that will last a long time and be relatively hassle free.
    I've managed to find myself a 2010 Prius 5 with the advanced tech with 101k miles on it. Was owned by an uncle, grandma, and finally transferred to the current owner (the nephew/grandson) just a few weeks ago. It has been serviced at their local toyota dealer for its entire life and after talking with the service manager there he told me it had oil changes and tires rotated religiously with them but it seemed they never really flushed the brake fluid or did a fuel injection service on it.
    The service manager said it needs both engine coolants to be flushed, a full transmission service and the brake fluid and fuel injection service and then it should be good for another "100K". The guy quoted me just under 750 for all the work and I was able to talk the seller down the full 750 from his asking price.
    So the current situation is...
    $8875 to the owner. $750 for the work. $139 for the inspection before purchase. and ~$250-300 for title and registration. This means I'm going to be dropping ~10k out of my pocket to drive off with a 101k mile 2010 Prius 5 w/ advanced tech.
    Sounds like a great deal to me. I just found out about the piston issue that comes up in the 2010 models and I'm reaching out here. Is that issue a deal breaker? 10k is about my limit here when it comes to spending capitol so I'd be taking some serious mile hikes or dropping to a prius 2 if I went with a 2012 model with slightly more miles.
    I'm hoping to get some opinions here. If that oil issue arises later on, is it something I can maintain without being a big hassle, or am I screwing my later self by buying this vehicle.
    Thanks a ton all!
  2. Devan R
    Devan R New Member
    Oregon
    This dude know what he is talking about and does it match with the issue I'm talking about here?
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,100
    6,966
    Texas Hill Country
    No, don't buy it. Arguably the worst Prius model ever made especially after grandma and all her relatives have owned it. High cost of repairs could easily add $5k in a year including engine failure. When buying used avoid 2010-15 Prius with 100k or more.
  4. JC91006
    16,936
    8,647
    This car may or may not be good for you. I have this exact 2010 Prius package 5. I will list some pros and cons
    Pros
    1. Is really advanced for a 2010 model car. Has many features that are just coming out as standard features for the 2020 model year cars.
    2. Has navigation (works and keeps you focused on the road and not on your phone).
    3. Has radar cruise control, great feature if you travel and don't want to worry about accelerating and braking on cruise.
    4. Car can parallel park for you, gimmicky feature at best.
    5. Overall decent car.
    Cons
    1. Has bigger 17 inch wheels, more expensive to replace and MPG is not as good as regular prius with 15" wheels
    2. Has poor leather interior (the vinyl around the leather surfaces are splitting on my car)
    3. Paint on the car is very thin, may already be fading/flaking on your car.
    4. My car burns oil (as with many 2010 models)
    5. Your HV battery is over 10 years old, may need a new replacement soon.
    At around 100k miles this car can still be very good. However you will have to spend some money to do some maintenance, the dealer is not the place to get it done. This is not the car where you spend $10k and think you'll go another 100k trouble free miles. I think you'll need to set aside $3000 just to not freak out when repairs come up (like a new HV battery). The rest of the car's mechanicals should hold up pretty well until you get close to 200k miles.
    At 100k miles and 10 years, you'll need the following preventative services
    Spark plugs change (these actually go for 120k miles but no better time than now to do it when everything is exposed)
    coolant change
    EGR circuit cleaning
    Transaxle fluid change
    Electric water pump (preventive replacement)
    Brake Fluid change (only if it tests bad)
    As this car has been religiously maintained, I would think it's in fairly good mechanical shape. Review the service records to make sure you don't duplicate what's already been done (as dealers will upsell and services may already have been done). You won't need the fuel injector service unless you're having issues.
    fotomoto likes this.
  5. BlkGenIII
    BlkGenIII Active Member
    86
    258
    SoCal
    Tough call but the ‘09-‘10 years were not the best for this car. You’re paying extra for the tech, which believe me is nice… I have a ‘12 Prius 5 w ATP and all of the modern conveniences found on an older car are great, but the engine is still the same as is found in the lower trims. While I didn’t find any issue with the bigger 17s and actually prefer them myself, I can understand other reservations people here have noted. If you’re looking for a Gen 3 you’re going to likely be better off with a newer one if you’re looking at that kind of mileage. Just my .02
  6. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Define: Long time
    Define: relatively hassle free
    Also: honest evaluation of your DIY abilities
    One can only guess if a 2010 is a good fit for you without these knowing these parameters.
