2010 Prius - 70k miles - Struts, Strut Insulators
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by vin_, Sep 18, 2018.
  1. vin_
    vin_ New Member
    Hi Friends,
    I have Prius III 2010. It has 70 k miles. Road conditions are very good in my driving routes. During the oil change today.. the dealership said I should "Replace Struts, Strut Insulators & Perform 4 Wheel Alignment". The two photos they gave me are attached. What do you think?...do these need to be replaced? Pls share your opinion.
    Also, they gave quote of $1260. Is this reasonable?
    Thanks in advance!
    Vin
  2. Tideland Prius
    16,673
    Mine are due for a replacement too (front shocks) at 90k miles. I was quoted (in Canadian dollars) $1,300-$1,400. Note that our labour is more expensive than in the US. (and this is before 12% sales tax).
    I'll let someone else chime in regarding the photos and the state of your struts.
    vin_ likes this.
  3. ASRDogman
    ASRDogman Senior Member
    8,048
    4,079
    Ouch! It's an easy job. You can get a complete set for about $100-150.
    That is just a dust boot. This plastic that always cracks and/or breaks.
    Does the car drive smooth? Do you hear a thud when you go over a bump?
    Also, does it drive straight? Do the tires wear evenly?
    #3 ASRDogman, Sep 18, 2018
    vin_ and Pluggo like this.
  4. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    I wouldn’t unless your car sways
    vin_ likes this.
  5. Mendel Leisk
    42,277
    Can you raise the front yourself, see if there's evidence of oil leaking from the shocks? Hard to judge from pictures, but it sure looks clean, like it's just a broken boot. Maybe paranoia, but in the back of my mind I'm wondering if they cut it. Don't listen to that voice I guess.
    To repair a broken boot you pretty much have to take everything apart anyway? This thread debates the need to repair boots:
    Strut dust boots necessary? | PriusChat
    #5 Mendel Leisk, Sep 18, 2018
    vin_ and Starship16 like this.
  6. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    Also, they may have been thinking that for the price of labor to replace those cracked boots you might as well do the shocks too. To me that's backward thinking. The plastic is only there to keep the shocks clean and to extend their life. With this much mileage behind you, you might as well wait until you are certain that the shocks are worn out.
    vin_ and Mendel Leisk like this.
  7. audiodave
    audiodave Active Member
    800
    272
    US
    vin_ likes this.
  8. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    Tell them to go pack sand.................
    Those photos were (I'll add "probably") taken with the car on a lift and the wheels hanging from the suspension, causing the struts to be at fully extended position. This stretches the dust covers to the maximum, which could easily be WHY they tore, especially if the boots were a bit brittle. Once the car is on the ground and sitting at normal ride height, those gaps are going to close up and probably disappear.
    Unless you're experiencing significant suspension/steering/odd tire wear issues, I would not, under any circumstances give them my money.
  9. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    I drove our 2010 with the boots in the same condition for over 70 k miles before swapping them out a couple of months back at 184 k miles (they were the original struts):).
    The parts price makes the job expensive, as it isn’t hard to do, just time consuming given you have to remove the windshield wiper cowling to have access to the top strut assembly nuts :(.
    But I waited with it prius and now that I have the new ones installed, the feel is different and better(y).
  10. yeldogt
    yeldogt Active Member
    810
    313
    NE
    There is no reason to replace if the only issue is the boot --- think about all the shocks running around w/o boots. The idea is to protect the rod from stone damage.
    depending on the types of roads -- shocks and struts can last over 200k if highway miles.
    most aftermarket are firmer -- so ......the difference is more noticeable when changed.
  11. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    Please tell us what dealer you went to in California.
    vin_ and Raytheeagle like this.
  12. Mendel Leisk
    42,277
    Could you tape it up? What would be the best tape?
  13. Starship16
    1,348
    1,455
    Beach Christmas
    We should call out the dealers that try and rip us off. I'm not saying that's the case here, but in the future I wonder if we should name the dealer?
    I agree with Mendel. I would find somebody to put some duct tape around it. Go to a tire shop, ask them to put it up on the lift, hand the guy the tape, and slip him 25 bucks.
    vin_ likes this.
  14. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    If you want to get inventive, take some black flexible plastic or cloth (like cut a garbage bag into a wide strip) wrap it around the gap area overlapping a little bit onto the good parts of the dust cover. Then use some black zip-ties at the top overlap and bottom overlap area. Make sure the zip-ties are seated into one of the "valleys" in the accordion. That would connect the two pieces of dust cover and not be blatantly obvious since it's in the shadows most of the time.
  15. Mendel Leisk
    42,277
    This stuff plus zip ties? It comes in various widths: 1.5" or 2" might be easier to handle.
    Might be a real handful though, coaxing it into place inside the springs, with a bit of tension. :(
    I think @TMR-JWAP 's idea is as good as anything, doesn't overthink it.
    #15 Mendel Leisk, Sep 19, 2018
    vin_ likes this.
  16. SDB54
    SDB54 Junior Member
    82
    32
    Northern CA
    Can you recommend "all in one" replacements for my 2006 front struts? Thanks!
  17. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    I’m a fan of OEM, so that’d be KYB. If you go the fully assembled route, ensure the top but is torques to spec ;).
    Otherwise you might have a rattle:cool:.
    Good luck and keep us posted (y).
    SDB54 likes this.
  18. SDB54
    SDB54 Junior Member
    82
    32
    Northern CA
    Would be a good meet up, but all I can offer is the apartment complex parking lot and some tools :)
