2010 Prius 9k Oil Change 2.9qt Consumption
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by hayden55, Oct 9, 2020.
  1. orenji
    orenji Senior Member
    5,887
    3,488
    Hole in drain pan?? What the heck!
  2. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Yep, double the speed of oil changes. I’m all for that to get back on Netflix ASAP.
  3. orenji
    5,887
    3,488
    No oil in the pan solves all issue with speed.
  4. rjparker
    rjparker Tu Humilde Sirviente
    10,158
    6,316
    Texas Hill Country
    This tread is worth setting up for email notifications.
    When is the last time you saw anyone checking their oil as they filled up? I know I do and often feel like the Lone Ranger.
    It not my mask, but it has a lot to do with the hood prop. Sometimes my sidekick does call me Kemosahbee.
    #24 rjparker, Nov 12, 2020
    ASRDogman likes this.
  5. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    I never check my oil as I’m filling up at a gas station because there an hour away, the dip stick reading would be all jacked up. I check my oil every other day in my garage before start up.
  6. ASRDogman
    ASRDogman Senior Member
    7,597
    3,916
    You are not alone....
    I do it sometimes. Depending on how long I have to wait...
    The ground is more or less level... And it sits for at least 3 minutes...
