For Sale 2010 Prius Auto Dimming Mirror with wiring harness
Discussion in 'Private Sales' started by toyotatrd, Feb 13, 2016.
  1. toyotatrd
    toyotatrd Junior Member
    38
    Knoxville, TN
    This is a 2010 Prius auto dimming mirror with wiring harness. I do not have the black plastic piece that covers the wires running to the headliner.. You can buy this part for $8-9 from Toyota.
    $125 shipped
  2. meteve
    meteve Junior Member
    Orange County, CA
    2013 Prius Plug-in
    Do you know the part number for the cover? What's the part number for the mirror? Does the mirror normally come with the harness?
  3. toyotatrd
    38
    Knoxville, TN
  4. toyotatrd
    38
    Knoxville, TN
    87810-0W260 mirror
    87818-47010 mirror cover .. you will need this.. $9 i think
    i also have wire harness.. you can just tap into your existing wiring
  5. veggieboy949
    veggieboy949 Junior Member
    So how hard would this be to install?
  6. toyotatrd
    38
    Knoxville, TN
    http://www.toyotapart.com/PT374-47100.pdf
    This is the install for the add on from toyota, but isnt the original add on from the factory. The mirror i have is the original mirror that came on a prius. The instructions show you how to install. Alot of this is plug and play.
  7. Rebound
    Rebound Senior Member
    3,698
    2,292
    Portland, OR
    Why is so much wiring needed to send 12V, Ground, and 12V standby signals? Only three pins run to that mirror.
  8. toyotatrd
    38
    Knoxville, TN
    I removed this from another Prius... I also took out the entire wiring harness running to it with plugs.
Loading...
