2010 Prius backup oem camera grid
Discussion in 'Gen 3 Prius Audio and Electronics' started by gatorback, Jan 3, 2026.
  1. gatorback
    gatorback Junior Member
    60
    I acquired a 2010 Gen-3 Prius. I like the 2014 prius backup oem camera, and would like it to have a grid feature. I think the grid lines are driven by the position of the steering wheel. Example:
    Deepseek indicated the OEM system had this capability if navigation is installed and the lines would be static / automatically displayed while in revers. My 2010 has no lines when put into reverse.
    Is there a procedure to either activate or load software for said feature?
    #1 gatorback, Jan 3, 2026
  2. ChapmanF
    18,894
    For 2010, grid lines were added by the Parking Assist ECU, if the car came with parking assist, which was an option in higher trims, separate from the navigation option.
    Without parking assist, the backup camera analog signal is wired directly to the nav unit, and the image is displayed without grid lines.
    In a car with parking assist, the backup camera wires go to the Parking Assist ECU, and it superimposes grid lines (based on data from the steering angle sensor), and sends the combined image digitally to the GVIF input on the back of the nav unit.
  3. gatorback
    60
    How do I termite if the car was outfitted with parking assist?
  4. ChapmanF
    18,894
    • Do you have this switch on the dash? [​IMG]
    • Do you have grid lines on the backup camera display?
    I think there's also a Toyota owners' site where you can supposedly enter your VIN and be told what trim and options the car had.
    I'd take that with a grain of salt, 'cause I put my VIN in and was told my car's a V, when it's very definitely a IV from birth....
  5. gatorback
    60
    @ChapmanF: Thank you for the explanation and responses. My backup camera does not display grid lines nor does the Prius have said switch on the dash.
    Is it possible to add said gridlines by plugging a Parking Assist ECU between the display and the camera? If yes, any links to success stories are appreciated.
  6. ChapmanF
    18,894
    I don't recall seeing threads where anyone has tried.
    There could be a number of things to add: a dash switch, a parking assist ECU, and the various perimeter sensors it communicates with; you might need to replace wire harnesses, or modify the ones in the car with additional wires and connectors.
    A quick check on feasibility would be to look in the wiring diagram:
    Toyota Service Information and Where To Find It | PriusChat
    The diagrams show wires that are and aren't present in different trim/option levels, showing them with asterisk-number combinations matching a legend on the diagram that tells which option goes with which asterisk-number. So, you can quickly get a sense of what wires, connections, and devices are found in a car with park assist that aren't in a car without it.
  7. notspam3
    notspam3 Member
    126
    67
    Toronto
    2024 Prius Prime
    XSE Premium
    When I replaced the failed BU camera on my camry the lines appeared after the new camera install. Look online for references on installing a new camera and calibration using the hidden maintenance menus for your vehicle. I think I remember that I turned that feature on during the calibration process.
  8. gatorback
    60
    I think you are indicating that thither is hidden menu for camera calibration, which can turn on the desired lines? Can you point me to the process to summon the hidden menu with a weblink?
