2010 Prius battery temperature and fan modes
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Shadyghabboun, Jul 28, 2022.
  1. Shadyghabboun
    Shadyghabboun New Member
    Amman
    2015 Prius c
    Hello everyone
    Hope you are well and in good health
    I have a 2010 prius and recently i started monitoring the temperature of the battery and to be honest i am a bit worried about what i found ... Ambient temperature here is around 37-40C
    And my battery temps are at the beginning of the trip were
    Temp1 37C
    Temp2 43C
    Temp 3 36.2C
    and after 30 mins drive it was
    Temp 1 50.2C
    Temp 2 53.4C
    Temp 3 48.9C
    And these temps are a bit on the high values and these temps were while the AC is on !!! But what i gound odd is that when i use the AC the fan mode is always on 1 and after the 52 it goes to mode 5 , however when i am not using the AC the fan mode goes up gradually...
    What do you suggest me to check first ?
    Best Regards
    Limey Geoff and bisco like this.
    52,818
    maybe it was designed that way?
    do you have toyota spec for battery temps to compare to?
  3. Shadyghabboun
    Amman
    2015 Prius c
    I was checking more posts about the temperature and it seems that even in hotter environments it should not reach such temps or at least for such a quick drive.
    as for the battery fan mode, I haven't found anything regarding this matter, it seems to have a somewhat complicated algorithm, but what I am referring to is that while using the AC the battery temperature rises up rather quickly, while it should be the other way around
  4. Shadyghabboun
    Amman
    2015 Prius c
    I am a bit of a newbie, and I was also wondering if this is the right place to post such a question or should I move it to another section?
  5. rjparker
    rjparker Tu Humilde Sirviente
    11,063
    6,933
    Texas Hill Country
    As a rule, if the car does not provide warnings it is ok. The system knows the ambient temperatures, load and normal battery temperature behaviors.
    Given the ambient is 40c/104f when parked, the battery starts out at that temp. We are around that ambient now; I will be driving for at least 30 minutes and will monitor.
    Results
    Drove about one hour total at 38c/101f ambient temperature. Hilly terrain around 60 mph. AC working well with a 24c/76f setpoint. The battery temp started at 38c and rose to 42c/107f.
    So your results may be high. My car has quality ceramic window film and a reflective silver paint. However I would suspect your battery air intake could be blocked or more likely the battery fan blower is dirty.
    #5 rjparker, Jul 28, 2022
    Xterra72 likes this.
  6. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Paging all the people who said turn you ac on and it will blow over the battery and cool down.
    I pulled almost everything from the back seats, bench, tannaeu cover, spare tire cover & etc out from the back to improve overall AC air circulation in the hatch. It helps out but you can only carry a single passenger. There are times when my battery stayed 107F with ac on full blast with hv fan on max
  7. CR94
    CR94 Senior Member
    2,825
    1,240
    Northwestern S.C.
    Battery temperature takes well over one hour to reach equilibrium.
    If you get in a situation requiring repeated braking (hills, congestion, many consecutive stop signs, whatever) it will go a lot higher.
  8. bisco
    52,818
    you're in the right place. unfortunately, there aren't a lot of people who monitor their temps and try to decrease them.
    there have been a few innovators though, if you can find the threads
  9. Noahdoge
    Noahdoge Active Member
    219
    148
    Mississippi
    Start here first. By your numbers it does not seem that the HV fan is functioning efficiently. It’s a very diy friendly job and will save you lots of $.
