2010 Prius Black Hubcaps
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Truffle_Shuffle, Jan 25, 2020.
  1. Truffle_Shuffle
    Truffle_Shuffle New Member
    Hermosa beach
    does anyone know some good black hub caps for 15in 2010 prius?
  2. PriusCamper
    PriusCamper Senior Member
    13,444
    5,428
    Pacific Northwest, USA
    Your best bet would be to have existing hubcaps modified in whatever way you prefer... I've never seen alternative hubcaps for Prius... But perhaps you could get what they call "moon discs" to work. These look like metal pizza pans that cover the whole wheel and are popular with the hypermile/highMPG enthusiasts that are looking to squeeze ever last drop of fuel efficiency out of their car.
  3. Truffle_Shuffle
    Hermosa beach
    Thanks, but what do you mean by modify. There’s lots of hub caps on amazon on stuff but there meant for aluminum wheels not alloy, and I guess there are no hubcaps for alloy wheels.
  4. PriusCamper
    13,444
    5,428
    Aluminum wheels and aluminum alloy wheels are slightly different names for the same thing. The hubcaps on Amazon may or may not fit... I've not seen any posts on here suggesting any specific alternatives, but if you went to a hub cap store in person you'd be able to confirm they fit before you buy them.
    As for modifying you could take the existing wheel ring and caps and use paint or plastic dip. You could also use bondo or fiberglass epoxy or use a soldering gun tip designed to melt plastic shapes into it.
    But before you do any of this you need a vision of how you'd like them to look. If you can explain or show a pic of the look you're going for, we'd better be able to help.
  5. Mendel Leisk
    42,323
    Spray what you've got with black Plasti-Dip? That way you can peel it off when you "come to your senses".
    PriusCamper likes this.
  6. Ueki
    Ueki Junior Member
    Novi,Mi
  7. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
    :cool:
  8. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Check the sales section of this site. You may find the hubcaps available for sale there.
  9. David9962000
    David9962000 Member
    141
    68
    2020 Prius
