2010 Prius Blown Engine - What are my options?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Rocketboy235, Oct 7, 2017.
  1. Gwenessa
    Gwenessa New Member
    Middletown De
    Hi Aaron
    I am having similar issues with my 2012 Prius 3. with 237,00 miles on it I had 2 diagnostics done and was told I blew head gasket, replace engine, one dealer quoted 6800 and 2nd 7000 with 140,000 miles on it
    Can you please let me know where you purchased engine from? If I trade I will not get anything for it
    Gwenessa
  2. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,145
    Franklin TN
    Hey I used car-part.com and found a local yard with one for $1000. This website is wonderful for finding parts near you
    amos likes this.
  3. SPANIKO DIYEI
    SPANIKO DIYEI New Member
    TAMPA
    SAME JUST HAPPENED TO ME, CAR WAS RUNNING FINE NO NOISES NO ISSUES OUT THE BLEW EXACT THING HAPPENED, UNDER CAR NOISE, THERE WAS NOT RUNNING HOT OR LOW OIL PRESSURE, CAR WAS RUNNING FINE DOING 70MPH FOR ABOUT 25 + MINUTES ON THE HIGHWAY AND BUMP THIS BIG HOLE HAPPEN, CAN SOMEBODY EXPLAIN WTH HAPPENED ???
  4. Mendel Leisk
    42,383
    Likely failed head gasket, coolant drawn into engine piston cylinder, and when piston attempts to come up it is stopped, since the coolant is not compressible. So piston arm connection breaks, and punches out hole in engine block wall.
    How many miles on it? Has the Exhaust Gas Recirculation (EGR) circuit and intake manifold been cleaned?
    Properly functioning EGR is needed to keep engine temperatures down. When it's clogged, engine temperature goes up, and everything is stressed more, leads to head gasket failure.
    amos and Montgomery like this.
  5. Prodigyplace
    12,720
    11,852
    Central Virginia
    Your caps lock key stuck??
  6. SPANIKO DIYEI
    TAMPA
    GAS ENGINE STILL RUNS WITH NOISE BUT RUNS, ILL BE SELLING THIS VEHICLE FOR PARTS, EVERYTHING IS AVAILABLE INTERESTED CALL ME 8139567465 IM IN TAMPA FL
  7. Mendel Leisk
    42,383
    C'mon, not now.
    Raytheeagle likes this.
  8. Prodigyplace
    12,720
    11,852
    Central Virginia
    Todd at Tampa Hybrids may be able to help.
    Mendel Leisk and mjoo like this.
