2010 Prius Brake, ABS, Traction Control Lights On
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jkan2001, Nov 28, 2017.
  1. Jkan2001
    Jkan2001 Member
    201
    63
    Dallas TX
    My wife's 2010 Prius with 143K miles had the ABS, Traction Control and Brake light all come on at once today when she was pulling in to the house. We bought it with about 135K miles and it's been running great after I did some basic maintenance on it (spark plugs, filters, oil etc).
    The car feels like it has no regenerative braking at all anymore and is just using the mechanical brakes now. If I coast the battery still charges, the car stops ok with more brake effort to engage the mechanical brakes. The pads are a bit low but still have maybe 2-3mm of material on all corners. Would the low pad wear sensor cause this fault? What else could I check?
    I plugged in a cheap obd2 handheld scanner and it had 0 engine fault codes stored. There are no other warning lights on besides Brake, TC, and ABS.
    #1 Jkan2001, Nov 28, 2017
    Pdaddy and amos like this.
    52,880
    you need a prius aware scanner like mini vci. how is the 12v health?
    Raytheeagle likes this.
  3. JC91006
    16,937
    8,647
    Check and see if there's an outstanding recall on your car, the brakes were one of the recall items
    amos likes this.
  4. Jkan2001
    Jkan2001 Member
    201
    63
    Dallas TX
    Is there a site to check? Which particular part of the brakes were under recall? I'd appreciate a link or recall # if you have it. Thanks
  5. Jkan2001
    Jkan2001 Member
    201
    63
    Dallas TX
  6. Jkan2001
    Jkan2001 Member
    201
    63
    Dallas TX
    Unfortunately I have not invested in one yet. Not sure on 12V health, I should get that tested. Is that a common problem when these 3 lights pop up? Car is getting 44mpg since we've had it so not sure if the 12V is bad.
  7. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    i say wheel bearing
  8. JC91006
    16,937
    8,647
    Log into Toyota.com owners portal, enter you vin there and you can look up the car's history and see outstanding recalls
  9. Jkan2001
    Jkan2001 Member
    201
    63
    Dallas TX
    I ran to the auto parts store and they tested the 12V battery, 450CCA Optima Yellow top and the battery is in good condition. I guess I'll need to get a system that can scan the brake system since there are no faults with the engine obd2 scanner.
  10. Jkan2001
    Jkan2001 Member
    201
    63
    Dallas TX
    Thanks, that site says no open recalls either
  11. Jkan2001
    Jkan2001 Member
    201
    63
    Dallas TX
    Can you elaborate? Did you have the same lights come on and the culprit was the wheel bearing? What's the action to fix this? Cheap or expensive part? DIY or leave it to a pro?
  12. tankyuong
    1,555
    662
    Central MO
    50 dollar part but hard to take off plus find out which wheel bearing withan abs scanner
  13. Jkan2001
    Jkan2001 Member
    201
    63
    Dallas TX
    Is it the ABS sensor that's integrated in the wheel bearing assembly/hub that fails? Is it not possible just to change the sensor?
    amos likes this.
  14. tankyuong
    1,555
    662
    Central MO
  15. Jkan2001
    Jkan2001 Member
    201
    63
    Dallas TX
    So the entire hub/sensor is only 50 bucks at the dealer? Looks like it's 138 for a Timken on rockauto. Front sensor is 100-145 for aftermarket.
    Is it common for these things to fail? Car has 143k miles.
    #15 Jkan2001, Nov 28, 2017
  16. tankyuong
    1,555
    662
    Central MO
    common repair especially if you hit a curb
    Ledorian and Princer like this.
  17. Jkan2001
    Jkan2001 Member
    201
    63
    Dallas TX
    No curbs were hit to my knowledge. She was just driving home and said they popped on as she turned on to our street. Which is more common, front or rear?
  18. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Was there a pothole or gravel on the road, or snow, any kind of situation where the wheel might have lost traction or slipped momentarily? If so, then it's common for the stated dashboard lights to come on.
    You can try to reset all the ECU modules by disconnecting the 12v auxiliary battery negative cable connection in the trunk and wait 30 seconds or so, then reconnect. If the error indicators persist after the reset, then your problem is real and needs to be resolved.
  19. ChapmanF
    19,044
    Nobody seems to have mentioned yet that you can retrieve the trouble codes from the brake computer by using a short length of wire and counting light blinks. You'll get two-digit codes instead of the five-character ones you see on a scantool, but the manual shows how to match them up. Lots of threads here have the details.
    All the other speculation in this thread about whether it might be a wheel speed sensor, or which one, or something else, etc., will typically be settled straight away when you have the codes, which will tell you, for example, if you have a speed sensor problem and, if so, which one.
    -Chap
    amos and padroo like this.
  20. Jkan2001
    Jkan2001 Member
    201
    63
    Dallas TX
    That's a good point. I did not know about jumpering the brake computer to get the light blinks. I'll search and see if I can find a thread on that procedure and what all the codes mean. You're right it's much better than speculation.
    EDIT: did a quick search and it seems like most the wire/counting the blink trick info is on Gen 2's is it the same for gen 3?
    #20 Jkan2001, Nov 29, 2017
