2010 Prius Brake actuator
Discussion in 'Gen 3 Prius Main Forum' started by Kevin Witte, Jan 4, 2026.
  1. Kevin Witte
    Kevin Witte New Member
    I just bought a new actuator and booster for my 2010 Prius. The old one was constantly trying to pressurize. Got both of them swapped out and now it seems to be working much better but I can’t get the traction control, brake, ABS, or check system lights on dash to go away. I cleared all the codes with a bluedriver. I have the Toyota tech stream software but can’t get it to connect with the USB cable I currently have. Any help ideas on clearing these lights? Thanks in advance.
    Kevin
  2. JC91006
    16,936
    8,647
    You need to run the Linear Valve Offset (I think that's what it's called) function with Techstream or similar software.
    Kevin Witte likes this.
  3. Frontporch
    Frontporch Active Member
    547
    128
    Nj
    When I did that work I followed along with a youtube video that used the Topdon tool to run through the procedure. At the time it was reasonably priced <$100, but the software license was only good for 1 year. Have not had any lights come on for over a year and the brakes are working fine.
  4. JC91006
    16,936
    8,647
    Op can ask a mechanic shop to do it, they should all have the proper software if they work on Toyota cars. It's a 5 minute job or maybe someone here has techstream and can do it?
  5. Mendel Leisk
    42,298
    Check with a dealership service department?
  6. ChapmanF
    18,983
    Before 'clearing' them, find out why they are on. That's the way you'll be able to solve the problem they are reporting.
    If your scan tool won't connect, you can get the trouble codes this way:
    Blink (a/k/a Flash) Codes – How to. | PriusChat
  7. Kevin Witte
    Thanks! Did some research on that. I bought a USB to OBD cable but techstream doesn’t recognize it. So, I just bought a VXdiag OBD and will try to run that.
  8. JC91006
    16,936
    8,647
    Make sure your 12v battery is fully charged before you begin the process. If the 12v is weak, it will fail.
